Blend Curve / Surface integration project
Chris_G
Post by Chris_G »
My 20yo son @MatteoG studies software development.
He is doing a business internship at my workshop this summer.
We would like to integrate Blend Curves, and Blend Surfaces into the Surface workbench.
I have already worked on this in the Curves workbench, so I hope we can push this a step further and integrate something similar into FreeCAD Surface workbench.
I have tried to write down a rough description of the planned features below :
BlendSurface_integration_1.0.pdf
(311.77 KiB) Downloaded 138 times
jnxd
Re: Blend Curve / Surface integration project
Post by jnxd »
Great to hear there's some developments happening in this direction. I had some interest in trying this myself, but B-Spline work in Sketcher is taking up my time. I'd like to stay in the loop though, if possible.
Chris_G
Post by Chris_G »
Thanks. We'll try to keep the thread regularly updated.
Today, he got an empty App::Feature of BlendCurve compiling fine, and the icon to show in the Gui.
That's a good first grip for upcoming work.
Chris_G
Post by Chris_G »
Here is an overview of the planned implementation.
Any advice or comment is welcome.
I don't think we will need a BlendPoint Feature, since it is rather low level.
Also, the Gordon Surface class won't get a feature for now, because we only plan to implement the basic Gordon algorithm, while a Feature would need much more preliminary work on the curve network.
Development is located here :
https://github.com/Matteo-Grellier/Free ... e/Blending
Zolko
Post by Zolko »
Chris_G wrote: Tue Jul 12, 2022 8:21 am We would like to integrate Blend Curves, and Blend Surfaces into the Surface workbench.
I'm not sure to know what these are, but I'd like to see "CurvedShapes" and "Curves" workbenches merged, because they are complementary:
  * CurvedShapes 1.0.1
  * Curves 0.4.1
If that's your goal, please yes, absolutely.
jnxd
Post by jnxd »
Zolko wrote: Mon Jul 18, 2022 1:37 pm
  * Curves 0.4.1
Their goal is to merge Curves with Surface workbench (which is present in FC main). What is the main difference between CurvedShapes and Curves that you find, and why do you believe both are needed?
Chris_G
Post by Chris_G »
No, our goal is not to merge the whole Curves workbench.
We plan only to implement the BlendCurve and the BlendSurface tools, like in the attached example :
Blend_Curve_Surface_example.FCStd
(40.28 KiB) Downloaded 53 times
Zolko
Post by Zolko »
jnxd wrote: Mon Jul 18, 2022 1:56 pm What is the main difference between CurvedShapes and Curves that you find, and why do you believe both are needed?
I use the resampling of curves a lot: airfoils come as coordinates, and different airfoil families have different number of points and distributions, especially at the leading edge, therefore the resulting sweep or loft can produce undesired warped surfaces if you use raw coordinates
jnxd
Post by jnxd »
Chris_G wrote: Mon Jul 18, 2022 1:29 pm Hello,
What is the meaning of the arrows?
Chris_G wrote: Mon Jul 18, 2022 1:29 pm I don't think we will need a BlendPoint Feature, since it is rather low level.
Blend point-like functionality may be useful in Sketcher. But that might require it's own implementation and doesn't appear to be relevant to the work in this thread.
Chris_G
Post by Chris_G »
jnxd wrote: Mon Jul 18, 2022 2:30 pm What is the meaning of the arrows?
It means "used by".
