I have the same problem with snapmaker postprocessor as in the first post.
I use
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
* LCInterlocking
With some of the other preprocessors I was able to generate the gcode successfully (marlin, linuxcnc, centroid).
I have tried all the solutions in this thread. By cribbing in the other postprocessors I applied the following imports in python code:
# sjj, 2023-01-02, begin
# Changed because of an error while postprocessiong
# see https://forum.freecadweb.org/viewtopic.php?p=640402#p640402
# see other postprocessors of version 0.20.1
#from PathScripts import PostUtils
#from PathScripts import PathUtils
import PathScripts.PostUtils as PostUtils
import PathScripts.PathUtils as PathUtils
# sjj, 2023-01-02, end
so the import works, but the error is again
15:02:30 snapmaker_freecad_post gcode postprocessor loaded.
15:02:40 snapmaker_freecad_post gcode postprocessor loaded.
15:02:43 snapmaker_freecad_post gcode postprocessor loaded.
15:02:43 <Path.Area> Area.cpp(2691): edge break point not found
15:02:43 helix_generator(59).generate((helix: <0.0, -56.0>
hole radius 5.2
inner radius 0.0
step over 0.5
start point 0.0
end point -5.1
step_down 6.0
tool diameter 6.0
direction CW
startAt Inside))
15:02:43 helix_generator.DEBUG: (124) - (single helix mode)
15:02:43 helix_generator.DEBUG: (144) - Radii: [2.2]
hole radius 5.2
inner radius 0.0
step over 0.5
start point 0.0
end point -5.1
step_down 6.0
tool diameter 6.0
direction CW
startAt Inside))
15:02:46 post: snapmaker_freecad(D:/OneDrives/OneDrive - La Gondola Barocca/_PCBüroLustheim/Eigene Dateien/CAD, Designer, Publisher/_CNC-Fräsungen/Vakuumplatte/vakuumplatte200x200.snapmaker.cnc, )
15:02:46 snapmaker_freecad_post gcode postprocessor loaded.
15:02:46 Show editor = 1
15:02:46 postprocessing...
15:02:46 Running the Python command 'Path_Post' failed:
File "C:\Program Files\FreeCAD\0.20.1.stable\Mod\Path\PathScripts\PathPost.py", line 437, in Activated
(fail, rc, filename) = self.exportObjectsWith(slist, job)
File "C:\Program Files\FreeCAD\0.20.1.stable\Mod\Path\PathScripts\PathPost.py", line 216, in exportObjectsWith
gcode = processor.export(objs, filename, postArgs)
File "C:\Program Files\FreeCAD\0.20.1.stable\Mod\Path\PathScripts\PathPostProcessor.py", line 105, in export
return self.script.export(obj, filename, args)
File "C:\Program Files/FreeCAD/0.20.1.stable/Mod/Path/PathScripts/post\snapmaker_freecad_post.py", line 204, in export
job = PathUtils.findParentJob(obj)
File "C:\Program Files\FreeCAD\0.20.1.stable\Mod\Path\PathScripts\PathUtils.py", line 405, in findParentJob
for i in obj.InList:
'_TempObject' object has no attribute 'InList'
Another google search for the error text at the end didn't get me anywhere.
Thank you for your help.
Many greetings
Sepp
