conda, osx-arm64, occt7.6
looo
Post by looo »
Starting a new topic for tracking the conda-forge osx-arm64 freecad build. My goal is:
1. make a freecad package available for osx-arm64 via conda package-manager
2. do a lot of testing
3. create a bundle for osx-arm64
4. update the rest of the conda freecad-packages to qt5.15 / occt7.6
5. do weekly builds for osx-arm64 via cross-compilation (not sure if this works for Freecad)
as already mentioned on GitHub there is now a Freecad-package available for osx-arm64 for testing:
conda create -n freecad_test freecad -c conda-forge -c freecad/label/dev
conda activate freecad_test
freecad
looo
Re: conda, osx-arm64, occt7.6
Post by looo »
first issue is not really related to osx-arm64 but as it is the first system where I try occt7.6 / external smesh 9.8.0.2 I think it's ok to work on this via the osx-arm64 build.
the error-message is:
dlopen(/Users/lo/mambaforge/envs/freecad_test/lib/Fem.so, 0x0002): symbol not found in flat namespace '__ZN10SMESH_Mesh14GetElementTypeEib'
Sounds like something has to be adopted in the Freecad-source. @wmayer
windows installer, snap and flatpak packages all use occt 7.6.2 successfully so I'm not sure if the issue really is on the FreeCAD side, unless it's arm specific.
looo
Post by looo »
adrianinsaval wrote: Tue Jul 05, 2022 9:29 pm windows installer, snap and flatpak packages all use occt 7.6.2 successfully so I'm not sure if the issue really is on the FreeCAD side, unless it's arm specific.
yes, but they are using the internal smesh which I don't do for some reasons.
I wouldn't know what to change there. How is this error actually triggered?
When looking at the internal smesh then there is this function
SMDSAbs_ElementType GetElementType( const int id, const bool iselem );
In the external smesh it's slightly different
SMDSAbs_ElementType GetElementType( const smIdType id, const bool iselem );
The difference is the int vs. smIdType. The smIdType is defined as
#ifndef SALOME_USE_64BIT_IDS
typedef std::int32_t smIdType;
#else
typedef std::int64_t smIdType;
#endif
So, the question is whether SALOME_USE_64BIT_IDS is differently set for the external smesh and FreeCAD.
Gift
Post by Gift »
looo wrote: Tue Jul 05, 2022 9:14 pm Starting a new topic for tracking the conda-forge osx-arm64 freecad build. My goal is:
freecad
This is great news
looo
Post by looo »
wmayer wrote: Wed Jul 06, 2022 9:20 am
It's triggered by changing to the fem-workbench or by trying to mesh a geometry with the mesh-design workbench.
wmayer wrote: Wed Jul 06, 2022 9:20 am #ifndef SALOME_USE_64BIT_IDS
#else
#endif
where is this defined?
looo wrote: Wed Jul 06, 2022 11:31 am where is this defined?
https://git.salome-platform.org/gitweb/ ... 3a;hb=HEAD
In a cloned smesh repository you will find it under SMESH/src/Kernel/src/Basics/smIdType.hxx
looo
Post by looo »
wmayer wrote: Wed Jul 06, 2022 3:00 pm
thanks, and I guess we should use std::int32_t to be compatible with the internal smesh. So SALOME_USE_64BIT_IDS should not be defined.
As a test you can replace
with
so that it doesn't mind whether SALOME_USE_64BIT_IDS is defined or not.
