PR 7100: FEM WB Elmer viscosity bug fix
Moderator: bernd
uwestoehr
Re: PR 7100: FEM WB Elmer viscosity bug fix
Post by uwestoehr »
uwestoehr wrote: Mon Oct 24, 2022 12:40 pm What remains is the problem that when I use water instead of air as fluid, there is no convergence. I tried hard but get no setup where water works. Do you?
Meanwhile I wrote the documentation of the Flow equation:
https://wiki.freecadweb.org/FEM_EquationFlow
But I did not yet have time to check what settings would be necessary to find a converging solution when water is used as fluid.
mst31
Post by mst31 »
Hello! Sorry for very long answer. Now I want to continue investigation of Elmer. But last version of FreeCAD (commit e188802ca6997d2564e7570ab648462e6a059f87) goes wrong trivially zero result. I tried my example that before worked fine. Also I created simple Flow example and it also has this problem. Have you any ideas about this problem?
tube.FCStd.7z
Simple Flow Elmer example
(314.95 KiB) Downloaded 54 times
RichB2k
Post by RichB2k »
Sounds like an Elmer issue with mesh names, as described here:
http://www.elmerfem.org/forum/viewtopic ... 404#p27404
Try installing a new version of Elmer?
Rich.
mst31
Post by mst31 »
Thank you! New version of Elmer solved this issue.
uwestoehr
Post by uwestoehr »
For information. I added the simple (2D) flow example to the FEM examples for the next release:
https://wiki.freecad.org/FEM_Examples
You can try this out with the latest Weekly build: https://github.com/FreeCAD/FreeCAD-Bund ... taller.exe
uwestoehr
Post by uwestoehr »
I have great news because now you can specify a velocity profile for flow simulations, see the description here: https://wiki.freecad.org/FEM_ConstraintFlowVelocity
(Note that you must setup new flow constraints for existing analyses because of the new functionality.)
I also fixed bugs that made _every_ flow simulation result wrong: the density and the viscosity were taken with a factor 1000 too high.
Therefore please don't trust the results you obtained so far with flow analyses!
Here is a build that includes this feature and the fixes:
mst31
Post by mst31 »
uwestoehr, thank you a lot of! I will try it.
thschrader
Post by thschrader »
uwestoehr wrote: Sun Mar 26, 2023 8:30 pm ...
Do you have a simple zip-package too?
