Challenges?
thomas-neemann
Re: Challenges?
Post by thomas-neemann »
papyblaise wrote: Mon May 29, 2023 7:43 am I don't understand your principle of saturating us with video in the form of challenges that are not drawn with Fc, do you want to prove that other software is more efficient than Fc :?:
especially since in your video you practice in an infentile way by stopping at each line to constrain it in length, I hope that your dream software is able to make equality which allows you to make the quotation in one :!:
I think there is a misunderstanding. i show that freecad is faster than inventor
thomas-neemann
Re: Challenges?
looking for a fast way to model this knot
here you can see how it is created (to understand the geometry)
https://www.youtube.com/watch?v=-8qI0O1eaNk
phpBB [video]
thomas-neemann
Re: Challenges?
I can't do it with the basic settings of freecad. are there settings that work better here?
1817tn.FCStd
(223.56 KiB) Downloaded 17 times
mhalil
Re: Challenges?
Post by mhalil »
Power of Curves WB :)
1817tn.FCStd
(311.18 KiB) Downloaded 17 times
thomas-neemann
Re: Challenges?
mhalil wrote: Sat Jun 03, 2023 5:06 pm Power of Curves WB :)
thank you very much, will try it
thomas-neemann
Re: Challenges?
I get stuck at the point where I want to select the freehand bspline in the 3d window
I have very little experience with the curves wb
1953tn.FCStd
(14.13 KiB) Downloaded 16 times
mhalil
Re: Challenges?
Post by mhalil »
thomas-neemann wrote: Sat Jun 03, 2023 5:57 pm I get stuck at the point where I want to select the freehand bspline in the 3d window
Double Click "Freehand_BSpline" in TreeView and enter the edit mode.
After, again double click "Freehand_BSpline" or Press ESC or Q, escape edit mode.
Now, You can select the bspline in the 3D Window :)
1953tn.FCStd
(92.61 KiB) Downloaded 14 times
thomas-neemann
Re: Challenges?
mhalil wrote: Sat Jun 03, 2023 6:10 pm
Thank you very much, it works now, I'm thrilled
thomas-neemann
Re: Challenges?
here is my suggestion, it is half the construction, so everything would take about 5 minutes
video:
viewtopic.php?p=685889#p685889
1028tn.FCStd
(135.48 KiB) Downloaded 17 times
edit
with the suggested solution from mhalil
Last edited by thomas-neemann on Tue Jun 06, 2023 3:30 am, edited 1 time in total.
papyblaise
Re: Challenges?
Post by papyblaise »
a long day of testing, another to advance end by end, I reconstituted a knot of an agricultural binding machine (harvester or baler), finally half to be complete you still have to do the 2nd parallel string
#1 is the strand that goes around the boot
#2 is the loop which was the heart of the knot and which is used to tighten it
#3 is the dead strand
noeud de machine.JPG (25.73 KiB) Viewed 1433 times
noeud.FCStd
(341.3 KiB) Downloaded 16 times
