Challenges?
- thomas-neemann
Challenges?
who can create this part fastest? it doesn't have to be parametric.
https://studycadcam.blogspot.com/2020/0 ... s-999.html
Last edited by thomas-neemann on Fri Jul 15, 2022 4:54 am, edited 1 time in total.
Re: Challenge?
Quick and dirty, incl. frame and title block:
Re: Challenge?
Datum Plane is redundant. Probably only need one polar pattern. Should have done the 3-point attachment to the sketches, not to the polar pattern geometry. But it works...
- challenge.FCStd
- (90.57 KiB) Downloaded 81 times
- thomas-neemann
Re: Challenge?
thank you for your cooperation. roughly how long did it take?
- thomas-neemann
Re: Challenge?
here is a suggestion in 3:20 min (without pauses for thought)
Re: Challenge?
It took about one hour. I was a bit too tired and made it a hexagon shape at first. Then it took a while to convert it to octagon.thomas-neemann wrote: ↑Fri Jun 24, 2022 3:45 am thank you for your cooperation. roughly how long did it take?
Now that I know how to build it my way, it won't take longer as relaxed 10 minutes.
- thomas-neemann
Re: Challenge?
I think this is a good time. can you upload the file to learn from it?
Re: Challenge?
About 5min, another method:
- papyblaise
Re: Challenge?
I don't understand what Thomas did
in more than 1 hour and with a lot of back and forth from one Wb to another
- 999.FCStd
- (100.29 KiB) Downloaded 68 times
- 999.JPG (21.88 KiB) Viewed 11528 times
- thomas-neemann
Re: Challenge?
the 5 mm is a good indication, i made a mistake there.
the model has a curve here?
edit
I read 5 mm, but it's 5 min. In my opinion, that's a very good value for this parametric result
Last edited by thomas-neemann on Fri Jun 24, 2022 8:05 am, edited 1 time in total.
