Page 1 of 63
Challenges?
Posted: Thu Jun 23, 2022 8:30 pm
by thomas-neemann
who can create this part fastest? it doesn't have to be parametric.
https://studycadcam.blogspot.com/2020/0 ... s-999.html
- 3D CAD EXERCISES (WWW.STUDYCADCAM.COM) 999.png (177.5 KiB) Viewed 12010 times
Re: Challenge?
Posted: Thu Jun 23, 2022 11:52 pm
by FBXL5
Quick and dirty, incl. frame and title block:
- Challenge.png (123.22 KiB) Viewed 11954 times
Re: Challenge?
Posted: Fri Jun 24, 2022 12:13 am
by edwilliams16
- Screen Shot 2022-06-23 at 2.08.43 PM.png (17.82 KiB) Viewed 11942 times
Datum Plane is redundant. Probably only need one polar pattern. Should have done the 3-point attachment to the sketches, not to the polar pattern geometry. But it works...
- Screen Shot 2022-06-23 at 2.10.35 PM.png (32.68 KiB) Viewed 11942 times
Re: Challenge?
Posted: Fri Jun 24, 2022 3:45 am
by thomas-neemann
FBXL5 wrote: ↑Thu Jun 23, 2022 11:52 pm
thank you for your cooperation. roughly how long did it take?
Re: Challenge?
Posted: Fri Jun 24, 2022 4:50 am
by thomas-neemann
here is a suggestion in 3:20 min (without pauses for thought)
- Bildschirmfoto_2022-06-24_06-17-22.png (23.03 KiB) Viewed 11870 times
Re: Challenge?
Posted: Fri Jun 24, 2022 7:21 am
by FBXL5
thomas-neemann wrote: ↑Fri Jun 24, 2022 3:45 am
It took about one hour. I was a bit too tired and made it a hexagon shape at first. Then it took a while to convert it to octagon.
Now that I know how to build it my way, it won't take longer as relaxed 10 minutes.
Re: Challenge?
Posted: Fri Jun 24, 2022 7:29 am
by thomas-neemann
FBXL5 wrote: ↑Fri Jun 24, 2022 7:21 am
I think this is a good time. can you upload the file to learn from it?
Re: Challenge?
Posted: Fri Jun 24, 2022 7:53 am
by wieszak17
About 5min, another method:
- 999.jpg (25.96 KiB) Viewed 11795 times
Re: Challenge?
Posted: Fri Jun 24, 2022 7:59 am
by papyblaise
I don't understand what Thomas did
in more than 1 hour and with a lot of back and forth from one Wb to another
Re: Challenge?
Posted: Fri Jun 24, 2022 8:02 am
by thomas-neemann
the 5 mm is a good indication, i made a mistake there.
the model has a curve here?
- 1.png (14.45 KiB) Viewed 11783 times
edit
I read 5 mm, but it's 5 min. In my opinion, that's a very good value for this parametric result
