[solved] Rotation - how to rotate twice?
dprojects
Re: Rotation - how to rotate twice?
Post by dprojects »
edwilliams16 wrote: Mon Jun 20, 2022 9:24 pm In my opinion using yaw/pitch/roll is not at all suitable for your application.
The Draft_Rotate function does all the dirty job for me very well. I don't know who coded the function but he did good job and the function it is very cool, this is how API should looks like.
What is very surprising to me, it not work with Pads, but it works also with Constriction Profiles made from PartDesign::Thickness, so I got exactly what I wanted. I can rotate Cube panels and also other more complicated objects.
Thanks
Darek
github.com/dprojects
dprojects
Post by dprojects »
mario52 wrote: Tue Jun 21, 2022 9:44 am example of macro Macro_Rotate_To_Point Image
mario
Thanks, Mario, I see you wrote a lot of code for FreeCAD. I have linked your site, this is good tutorial how to deal with things at FreeCAD.
Thanks
Darek
keithsloan52
Re: [solved] Rotation - how to rotate twice?
Post by keithsloan52 »
I think Munther Hindi has a better solution
If you want to rotate objects programmatically (say in a Macro) using two successive rotations about two different axes then you could use something like:
rot1 = FreeCAD.Rotation(FreeCAD.Vector(x1, y1, z1), angle1) # rotation about axis with components x1, y1,z1 with angle1 in degrees
rot2 = FreeCAD.Rotation(FreeCAD.Vector(x2, y2, z2), angle2) # rotation about axis with components x2, y2, z2 with angle2 in degrees
Then to rotate object about the two axes, some thing like,
obj.Placement.Rotation = rot2*rot1 # this rotates about axis 1, then axis2, but double check visually.
edwilliams16
Post by edwilliams16 »
freedman
Post by freedman »
I finished my part design assembly last night, I will post the code in the next few days. Maybe that will help.
Been building models to test.
GIF dialog UI.gif (207.61 KiB) Viewed 871 times
dprojects
Post by dprojects »
freedman wrote: Wed Dec 14, 2022 12:17 am I finished my part design assembly last night, I will post the code in the next few days. Maybe that will help.
Very nice. This support containers like LinkGroup? Currently I want to improve this part at Woodworking workbench. The containers are little "not supported" well as they should. What I saw that getGlobalPlacement is not correct in case of LinkGroup. It works only with containers like Part, Body.
Thanks
Darek
freedman
Post by freedman »
That's where I am also, I was hoping to look at Links but what was more important to me is fast simulations. I think I got Links to work in another macro but maybe LinkGroups were a problem.
dprojects
Post by dprojects »
freedman wrote: Wed Dec 14, 2022 7:13 pm That's where I am also, I was hoping to look at Links but what was more important to me is fast simulations. I think I got Links to work in another macro but maybe LinkGroups were a problem.
This is not only problem with LinkGroup but the vertices for faces and edges are not updated even for Body and Part containers: https://forum.freecadweb.org/viewtopic.php?f=22&t=74447
Thanks
Darek
HardCAD
Post by HardCAD »
For rotating pads more than once, a trick I found useful is to make a fusion of the pad with something (part > fusion of the two parts).
This resets the rotation to zero so you can add another rotation without having to go through the math/scripts.
dprojects
Post by dprojects »
HardCAD wrote: Fri Feb 03, 2023 5:50 pm resets the rotation to zero
You read my mind, bad boy ;-) Reset rotation to zero can be used to determine the plane correctly for rotated objects but I didn't released it yet with this way ;-) Are you time traveler? ;-) LOL
Thanks
Darek
