[Enhancing Request] add a Body Directory - (replaced)
Kartoffelpüre
Post by Kartoffelpüre »
--> I replaced this Enhancement Request with this one
If I try to Export Data I have to select Bodies for the Export. Sometimes It's Difficult to Select the Bodies I want.
Please add a Body Group to the Model Tree.
Strukturierte Körper.png (67.75 KiB) Viewed 3090 times
Some skills this directory should have:
  • Automatically Updating Main-group (Body, Surface, Curves, Annotation)
  • Ability to add new Directories where I could drag and drop object into it from List or graphic area
  • It should be possible to select a Directory for Export Files
    • The structure with Subdirectories is used for Exporting, if destination file type allow structured Data (e.g. STEP)
Re: [Enhancing Request] add a Body Directory
Possibly addressed in @realthunder's pending issue #2759
Kartoffelpüre
@Kunda1 Do you know about updates in this case? I'm not sure how I have to understand the mentioned Issue.
Sorry, I don't know.
I would rather suggest that you make a macro to select all bodies, a persistent object in the tree who's only purpose is to gather other objects by type is a waste IMO so I don't see this being implemented any time soon.
Kartoffelpüre
adrianinsaval wrote: Sun May 28, 2023 8:21 pm I would rather suggest that you make a macro to select all bodies, a persistent object in the tree who's only purpose is to gather other objects by type is a waste IMO so I don't see this being implemented any time soon.
I know this type of directory from other CAD where I use them in many cases.
I see a lot of possibilities.
Body Directory:
  • Choose the directory to have a "Select all"
  • Fast access to bodies and their properties
    The Names of the Bodys in this directory could depending to properties:
    • the name of last Feature modified the Body
    • Volume
    • Max dimension X/Y/Z
    • Custom Properties
  • A kind of dynamical grouping could help group bodies by same geometry or property and help detect the count of identical
  • Allow creating Sub-Directories
    • Sub-Directories could help structure a Bom for a bomtable.
    • Sub-Directories could help structure acording to certain needs.
You can use groups to group things yourself, for selecting all bodies a macro is a better choice
Kartoffelpüre
adrianinsaval wrote: Fri Jun 02, 2023 7:03 pm
...for selecting all bodies a macro is a better choice
Only If it's written by professionals (not me)
adrianinsaval wrote: Fri Jun 02, 2023 7:03 pm You can use groups to group things yourself, ...
that's nice but kind of Data management by logic helps to not forget to and update something.
Kartoffelpüre wrote: Mon Jun 05, 2023 1:47 pm Only If it's written by professionals (not me)
Half of FreeCAD is written by amateurs, don't be afraid to try. A macro to select all elements of a certain type shouldn't be too complicated
