ShaftDesign not fully functional on v0.20
johnwang
Re: ShaftDesign not fully functional on v0.20
Post by johnwang »
adrianinsaval wrote: Tue May 31, 2022 9:36 pm @uwestoehr thoughts? seems it doesn't work out of the box and might be a bad idea to use it anyways, should we remove the shaft design wizard?
Here is kind the reason why it is not working. Because PLOT changed.
https://forum.freecadweb.org/viewtopic. ... ac#p598938
johnwang
Post by johnwang »
Kuzma30 wrote: Wed Jun 01, 2022 5:41 am
Figured out another way to fix.
Plot WB is no longer needed. Its function is moved into FC core.
Change to FreeCAD.Plot like this to access the new FC core plot function:
class Diagram:
    def create(self, title, function, xlength, xname, xunit, xscale, yname, yunit, yscale, numxpoints):
        # Initialize
        from FreeCAD.Plot import Plot
uwestoehr
Post by uwestoehr »
Kuzma30 wrote: Wed Jun 01, 2022 5:41 am Than make it plot diagram.
It has a bug we must fix, yes. I hope that a Pyhtionist like @chennes can help me here since I have much to do with the release.
The bug I get is
File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\WizardShaft.py", line 117, in slotQz
13:19:22      self.showDiagram("Qz")
13:19:22    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\WizardShaft.py", line 97, in showDiagram
13:19:22      self.shaft.showDiagram(diagram)
13:19:22    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\Shaft.py", line 223, in showDiagram
13:19:22      self.diagrams[self.F[ax].name].close()
13:19:22    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\ShaftDiagram.py", line 88, in close
13:19:22      self.win.parent().close()
13:17:45    AttributeError: 'Diagram' object has no attribute 'win'
To reproduce
- in the PD workbench go to menu Part Design -> Shaft design wizard
- in the appearing dialog click on the button "Q [z]"
- in case the Plot WB is not yet installed you are prompted to do so (then restart FC and repeat the first step)
Sometimes I have the general error that I am told the Plot WB is not installed and I should do so using the Addon-Manager. This is now since FC 0.20. @chennes can you please have a look if there is maybe a wrong config file?
johnwang wrote: Wed Jun 01, 2022 10:24 am Figured out another way to fix.
Change to FreeCAD.Plot like this to access the new plot function:
class Diagram:
        # Initialize
Can you make a PR?
johnwang
Post by johnwang »
adrianinsaval wrote: Wed Jun 01, 2022 11:29 am Can you make a PR?
I'm not good at it. If someone like and convenient, he can. I don't need that credit.
Here is the screenshot with the FC core Plot. No Plot WB is needed.
new shear.jpg (92.26 KiB) Viewed 1677 times
uwestoehr
Post by uwestoehr »
I tried this but I still get this error:
13:41:44  Traceback (most recent call last):
13:41:44    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\WizardShaft.py", line 117, in slotQz
13:41:44      self.showDiagram("Qz")
13:41:44    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\WizardShaft.py", line 97, in showDiagram
13:41:44      self.shaft.showDiagram(diagram)
13:41:44    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\Shaft.py", line 223, in showDiagram
13:41:44      self.diagrams[self.F[ax].name].close()
13:41:44    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\ShaftDiagram.py", line 64, in close
13:41:44      self.win.parent().close()
13:41:44  AttributeError: 'Diagram' object has no attribute 'win'
johnwang
Post by johnwang »
uwestoehr wrote: Wed Jun 01, 2022 11:42 am I tried this but I still get this error:
I don't have these errors. I don't have Plot WB on my pc.
Try remove Plot WB if you have.
Edit: I think I saw the same error with the 1st way of fix.
uwestoehr
Post by uwestoehr »
johnwang wrote: Wed Jun 01, 2022 11:49 am Try remove Plot WB if you have.
I removed it and restarted FC but the error persists.
user1234
Post by user1234 »
uwestoehr wrote: Wed Jun 01, 2022 2:07 am
Not for 0.20, it will stay for now.
I would say that. Maybe a very dirty solution, remove the menu entry?
Greetings
user1234
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Wed Jun 01, 2022 11:57 am I removed it and restarted FC but the error persists.
Seems I had something cached somewhere. Now it works and I committed the fix:
https://github.com/FreeCAD/FreeCAD/commit/2de25dd04e
@Kuzma30 , please test if this works for you as well now.
