ShaftDesign not fully functional on v0.20
Kuzma30
Post by Kuzma30 »
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.20.28968 (Git) Snap 47
Hash: 03f38526172d8bc6274ddfb5cdd3ad6b691f5f56
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, OCC 7.6.2
Locale: Ukrainian/Ukraine (uk_UA)
  * Plot 2022.4.17
There is some problems with ShaftDesign Wizard
1. Problem with translations. https://github.com/FreeCAD/FreeCAD-tran ... s/issues/4 We have translated string in crowdin and in .ts files but no on GUI.
2. Problem with Plot. It don't works
for some buttons it show errors, for example (Qz)
12:30:01  Traceback (most recent call last):
12:30:01    File "/snap/freecad/47/usr/Mod/PartDesign/WizardShaft/WizardShaft.py", line 117, in slotQz
12:30:01      self.showDiagram("Qz")
12:30:01    File "/snap/freecad/47/usr/Mod/PartDesign/WizardShaft/WizardShaft.py", line 97, in showDiagram
12:30:01      self.shaft.showDiagram(diagram)
12:30:01    File "/snap/freecad/47/usr/Mod/PartDesign/WizardShaft/Shaft.py", line 223, in showDiagram
12:30:01      self.diagrams[self.F[ax].name].close()
12:30:01    File "/snap/freecad/47/usr/Mod/PartDesign/WizardShaft/ShaftDiagram.py", line 88, in close
12:30:01      self.win.parent().close()
12:30:01  AttributeError: 'Diagram' object has no attribute 'win'
for another (sigma[z]) it show pop-up dialog "Missing module". You may have to install the Plot add-on.
Detail show
  File "/snap/freecad/47/usr/Mod/PartDesign/WizardShaft/Shaft.py", line 266, in showDiagram
    self.diagrams[self.sigmaN[ax].name].create(text[0], self.sigmaN[ax], self.getLengthTo(len(self.segments)) / 1000.0, text[1], text[2], 1000.0, text[3], text[4], 1.0E-6, 10)
  File "/snap/freecad/47/usr/Mod/PartDesign/WizardShaft/ShaftDiagram.py", line 30, in create
    from freecad.plot import Plot
ImportError: cannot import name 'Plot' from 'freecad.plot' (/home/alexandr/snap/freecad/common/Mod/Plot/./freecad/plot/__init__.py)
As write in wiki "From FreeCAD 0.20 on plot module is already packaged within the program, so you don't need to install any add-on, but just type " (https://wiki.freecadweb.org/Plot_Workbench) But designshaft don't work without and with Plot WB installed.
RealThunder's A3 Wiki translation, join the project https://crowdin.com/project/freecad-asm3-wiki
johnwang
Re: ShaftDesign not fully functional on v0.20
Post by johnwang »
I tried to use matplotlib which is included in FC.
In \Mod\PartDesign\WizardShaft\ShaftDiagram.py, Find 'class Diagram' and change to:
class Diagram:
    def create(self, title, function, xlength, xname, xunit, xscale, yname, yunit, yscale, numxpoints):
        # Initialize
        #from freecad.plot import Plot
        import matplotlib.pyplot as Plot
and at the end of this 'def create', change to:
        # Create plot
        #self.plot()
        Plot.plot(self.xpoints,self.ypoints)
        Plot.show()
Kuzma30
Post by Kuzma30 »
johnwang wrote: Tue May 31, 2022 10:55 am I tried to use matplotlib which is included in FC.
Thanks. I make your changes and comment self.thePlot = Plot.getPlot() line
I have error with it
  File "/home/alexandr/Kuzma30/FreeCAD-build-master/Mod/PartDesign/WizardShaft/WizardShaft.py", line 117, in slotQz
  File "/home/alexandr/Kuzma30/FreeCAD-build-master/Mod/PartDesign/WizardShaft/WizardShaft.py", line 97, in showDiagram
  File "/home/alexandr/Kuzma30/FreeCAD-build-master/Mod/PartDesign/WizardShaft/Shaft.py", line 227, in showDiagram
    self.diagrams[self.F[ax].name].create(text[0], self.F[ax], self.getLengthTo(len(self.segments)) / 1000.0, text[1], text[2], 1000.0, text[3], text[4], 1.0, 10)
  File "/home/alexandr/Kuzma30/FreeCAD-build-master/Mod/PartDesign/WizardShaft/ShaftDiagram.py", line 46, in create
AttributeError: module 'matplotlib.pyplot' has no attribute 'getPlot'
^CTraceback (most recent call last):
  File "/home/alexandr/Kuzma30/FreeCAD-build-master/Mod/PartDesign/WizardShaft/WizardShaft.py", line 166, in isAllowedAlterDocument
    def isAllowedAlterDocument(self):
Can you make PR to upstream?
johnwang
Post by johnwang »
Kuzma30 wrote: Tue May 31, 2022 11:28 am
Yes. It need to be commented out.
        # Get the plot object from the window
        #self.thePlot = Plot.getPlot()
This is just a quick test. Haven't consider other part of the code. Don't know if it worth a PR.
Kuzma30
Post by Kuzma30 »
johnwang wrote: Tue May 31, 2022 11:41 am
Of course it worth. Without this changes it doesn`t work on 0.20
user1234
Post by user1234 »
See, https://forum.freecadweb.org/viewtopic.php?f=10&t=59688.
Also i do not like the shaft wizard, because it is not the way as it work in real life. I allow me to quote myself:
user1234 wrote: Fri Jun 25, 2021 10:01 pm So i would wipe the Shaft Wizard it from PartDesign also. Also the Shaft Wizard uses FEM constraints without a FEM Analysis Container, which is useless. And a analysis tool has nothing to do in PartDesign. This things should always be separated.
And also one generally technical thing: I never used the Shaft Wizard, so i can only guess, if the things below are included.
I guess the plot only makes a F(x), M(x), ..... means forces and so on from a running x. I you do that on discontinuous (and also relative discontinuous) elements, then you must include factors for notch effects, roughness of surfaces, size, application, ....... . If this is not included the calculation is invalid (often extremely). And If you do not know that and see, ahhh that result is OK (sigma is OK), then it could be dangerous! So my conclusion is that if you want do make a shaft, you should do it with normal FreeCAD workbenches and if you want to analyze it, you should do it yourself or with FEM. And if anyone is familiar with FreeCAD, you can use later the Wizard with the addon anyway (if it works).
Greetings
user1234
edit: typo
Kuzma30
Post by Kuzma30 »
user1234 wrote: Tue May 31, 2022 1:24 pm See, https://forum.freecadweb.org/viewtopic.php?f=10&t=59688.
Greetings
user1234
edit: typo
I am not real user of ShaftDesign. I test it while trying to resolve translations problem.
If it provide incorrect results it must be deleted :)
@uwestoehr thoughts? seems it doesn't work out of the box and might be a bad idea to use it anyways, should we remove the shaft design wizard?
uwestoehr
Post by uwestoehr »
adrianinsaval wrote: Tue May 31, 2022 9:36 pm @uwestoehr thoughts? seems it doesn't work out of the box and might be a bad idea to use it anyways, should we remove the shaft design wizard?
Not for 0.20, it will stay for now.
Kuzma30
Post by Kuzma30 »
uwestoehr wrote: Wed Jun 01, 2022 2:07 am
Than make it plot diagram.
