ShaftDesign not fully functional on v0.20
uwestoehr
Re: ShaftDesign not fully functional on v0.20
Post by uwestoehr »
There is now for me only this bug left:
- in the PD workbench go to menu Part Design -> Shaft design wizard
- in the appearing dialog click on the button "w [z]"
result:
16:16:35  Traceback (most recent call last):
16:16:35    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\WizardShaft.py", line 131, in slotWz
16:16:35      self.showDiagram("wz")
16:16:35    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\WizardShaft.py", line 97, in showDiagram
16:16:35      self.shaft.showDiagram(diagram)
16:16:35    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\Shaft.py", line 249, in showDiagram
16:16:35      self.diagrams[self.w[ax].name].close()
16:16:35    File "D:\FreeCAD-build\Mod\PartDesign\WizardShaft\ShaftDiagram.py", line 88, in close
16:16:35      self.win.parent().close()
16:16:35  RuntimeError: Internal C++ object (Plot) already deleted.
@johnwang, do you have an idea? It seems the code tried to close a plot that is not existent.
Kuzma30
Post by Kuzma30 »
uwestoehr wrote: Wed Jun 01, 2022 2:15 pm
uwestoehr wrote: Wed Jun 01, 2022 11:57 am I removed it and restarted FC but the error persists.
Seems I had something cached somewhere. Now it works and I committed the fix:
https://github.com/FreeCAD/FreeCAD/commit/2de25dd04e
@Kuzma30 , please test if this works for you as well now.
Test on initial example. All works (Q[z], Mb[y], sigma[z] and sigmab[y]), except w[z]
18:03:55  Traceback (most recent call last):
18:03:55    File "/home/aleksandr/test_crowdin/FreeCAD-build-master/Mod/PartDesign/WizardShaft/WizardShaft.py", line 131, in slotWz
18:03:55      self.showDiagram("wz")
18:03:55    File "/home/aleksandr/test_crowdin/FreeCAD-build-master/Mod/PartDesign/WizardShaft/WizardShaft.py", line 97, in showDiagram
18:03:55      self.shaft.showDiagram(diagram)
18:03:55    File "/home/aleksandr/test_crowdin/FreeCAD-build-master/Mod/PartDesign/WizardShaft/Shaft.py", line 253, in showDiagram
18:03:55      self.diagrams[self.w[ax].name].create(text[0], self.w[ax], self.getLengthTo(len(self.segments)) / 1000.0, text[1], text[2], 1000.0, text[3], text[4], 1000.0, 30)
18:03:55    File "/home/aleksandr/test_crowdin/FreeCAD-build-master/Mod/PartDesign/WizardShaft/ShaftDiagram.py", line 54, in create
18:03:55      self.plot()
18:03:55    File "/home/aleksandr/test_crowdin/FreeCAD-build-master/Mod/PartDesign/WizardShaft/ShaftDiagram.py", line 82, in plot
18:03:55      axes.set_xlim(right = max(self.xpoints) * 1.05)
18:03:55  ValueError: max() arg is an empty sequence
RealThunder's A3 Wiki translation, join the project https://crowdin.com/project/freecad-asm3-wiki
chennes
Post by chennes »
I get the same error as @Kuzma30 -- it seems to stem from the following comment in SegmentFunction.py:
        # Coverity has reported a problem that I_i, C_i0 or C_i1:
        # Bad use of null-like value (CIDs are 192609, 192611, 192616)
        # Since this code doesn't seem to be used anywhere the problematic
        # part will be commented out
        #for xval in sorted(xvals):
        #    if xval in divs:
        #        i = self.intfunc.index(xval)
        #        (begin,  length) = self.intfunc.interval(xval)
        #        I_i = self.intfunc.value(xval)
        #        C_i0 = self.boundaries[2 * i]
        #        C_i1 = self.boundaries[2 * i + 1]
        #        FreeCAD.Console.PrintMessage("Interval %u: %f to %f, I_i: %f, C_i0: %f, C_i1: %f\n" % (i,  begin, length,  I_i,  C_i0,  C_i1))
        #    xresult.append(xval)
        #    # w(xval) = (transfunc(xval) + C_i0 * xval + C_i1) / (E * I_i)
        #    value = (self.transfunc.value(xval)  + C_i0 * xval + C_i1) / (E * I_i)
        #    yresult.append(value)
        return (xresult, yresult)
So the code that actually creates xresult and yresult has been commented out to appease the static analyzer. I've submitted a PR that reverts this change -- I don't know if Coverity is concerned about a case in which those array indices are out of bounds, but at any rate it seems to be it's better to have working code that might have a bug, than non-functional code that certainly has a bug!
https://github.com/FreeCAD/FreeCAD/pull/6954
Chris Hennes
Pioneer Library System
Merged in git commit d860c4b
Thanks @chennes!
johnwang
Post by johnwang »
uwestoehr wrote: Wed Jun 01, 2022 2:15 pm I committed the fix:
Thx.
johnwang
Post by johnwang »
user1234 wrote: Wed Jun 01, 2022 2:14 pm I would say that. Maybe a very dirty solution, remove the menu entry?
It is hard to get in, so if it is there for a long time, better keep it.
It is really a good example to do some design tools. Hope it will inspire others to get started
user1234
Post by user1234 »
johnwang wrote: Thu Jun 02, 2022 9:10 am It is really a good example to do some design tools. Hope it will inspire others to get started
I do not agree. Only plotting along an axis through a know section, gives never valid result (no factors of notches, surfaces, section areas, load variation ..... which are some each other braced). Even a simple stepped shaft will not be valid. I think this functions really dangerous, if some does not know more about constructing and looks only on the sigma (tension) or tau (shear).
Greetings
user1234
edit: blue
uwestoehr
Post by uwestoehr »
user1234 wrote: Thu Jun 02, 2022 12:53 pm Only plotting along an axis through a know section, gives never valid result (no factors of notches, surfaces, section areas, load variation
I agree. It is really dangerous when people would take these results. I mean the feature does not even allow you to set the material parameters. Now it is too late but for the next FreeCAD version, the feature should be moved to the FEM workbench so that one can set the material parameters and also use it for shafts in a custom design (e.g. D-shape tip like for many electric motors, holes etc.)
user1234
Post by user1234 »
uwestoehr wrote: Thu Jun 02, 2022 1:12 pm Now it is too late
I know, and agree with you. If it is now in it, it is no bonebreaker. I just wanted to point it out, why it is no good function.
Greetings
user1234
david69
Post by david69 »
checking some issue with translations on Crowdin, https://github.com/FreeCAD/FreeCAD-tran ... s/issues/4, I don't understand the meaning of edge. can you enlight me pls?
Capture d’écran du 2023-01-02 11-57-41.png (26.34 KiB) Viewed 1112 times
@kaktus it may interest you too.
adding: the wording corresponding to Constrain type are not proposed for translation: Force, Fixed, Bearing...
