Stable parametric model of a bridge, export as ifc in the bim process for the structural engineer
- thomas-neemann
Re: Stable parametric model of a bridge, export as ifc in the bim process for the structural engineer
Very cool! At some point I'd like to have a kind of back-and-forth workflow between proper volumetric structural objects and wire diagram... So you could model with, say, your design intent, export the wire schema for structural calculation, then adapt back your design instantly or even automatically
- thomas-neemann
