Hi everyone,
I am on realthunder branch.
I have an issue with PIE menu.
I am on macos Catalina 10,15,7
I create a custom toolbar which I want to call by pressing a key. When I assign a letter, I can call the customized toolbar.
When I assign one of the F keys (F16,F17...) I have nothing. The customized toolbar does not appear.
The tab key can call pie menu.
Thanks for your help
Link Branch - Pie Menu issue
Re: Link Branch - Pie Menu issue
Mod edit: please keep all posts regarding Link branch to this subforum. Please don't necrobump old posts (especially with Link branch related issues that are actually off-topic). Instead, start a new thread and reference the old thread.
- adrianinsaval
It's confusing because pie-menu is also forked by realthunder, as you know, which also has a different keyboard shortcut scheme and other tweaks. This then can 'pollute' other threads that are not LS3 related.
I am using latest Branch and Fkeys are working Just fine.lebearnais wrote: ↑Mon May 09, 2022 5:20 pm Hi everyone,
I have created a video on how to make custom shortcuts please check them out Just to be sure you are doing things correct.
https://youtu.be/L_QQrg3A6q4
Thanks a lot for your answer.
Everything is working exept when you use function keys.... F1 F2 F3 ..... and that is my problem.
I have a streamdeck and I wanted to use F11, F12.... virtual keys to access to pi menu.
- LordMadJack
Just in case... Do you use F1 F2 F3 or Fn+F1, Fn+F2, Fn+F3
