Running the Python command 'Draft_Move' failed
proghettolab
Post by proghettolab »
Hi all.
Since I upgraded to Ubuntu 22.04 i have problems with freecad 0.19.
First of all, every time I switch from the Start workbench to Arch, BIM or Draft, freecad responds with:
<built-in function SoFieldContainer_getField> returned a result with an exception set
File "<string>", line 434, in Activated
File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1635, in show
self.setTrackers()
File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1679, in setTrackers
self.grid = trackers.gridTracker()
File "/usr/share/freecad/Mod/Draft/draftguitools/gui_trackers.py", line 974, in __init__
pick.style.setValue(coin.SoPickStyle.UNPICKABLE)
File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3989, in __getattr__
field = self.getField(name)
File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3873, in getField
return _coin.SoFieldContainer_getField(self, name)
Then, when I try to use any command, for example Move, the following error appears in the console
Running the Python command 'Draft_Move' failed:
File "/usr/share/freecad/Mod/Draft/draftguitools/gui_move.py", line 69, in Activated
super(Move, self).Activated(self.name,
File "/usr/share/freecad/Mod/Draft/draftguitools/gui_base_original.py", line 154, in Activated
Gui.Snapper.setTrackers()
My Python version in 3.10.4
Using Appimage, on the other hand, everything is fine.
OS: Ubuntu 22.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.10.2
Qt version: 5.15.2
OCC version: 7.5.1
Locale: Italian/Italy (it_IT)
Thanks in advance for the help.
thomas-neemann
Re: Running the Python command 'Draft_Move' failed
Post by thomas-neemann »
proghettolab wrote: Sat May 07, 2022 10:03 am ..
with 22.04 there still seems to be problems
marioalexis
Post by marioalexis »
There is an incompatibility between your current version of Pivy and Python 3.10.
The same as here: https://forum.freecadweb.org/viewtopic.php?f=3&t=67542
Is there an upstream pivy ticket tracking this?
dpward
Post by dpward »
Kunda1 wrote: Sun May 08, 2022 1:39 am Is there an upstream pivy ticket tracking this?
Yes, a fix is released now:
https://bugs.launchpad.net/ubuntu/+sour ... ug/2000840
thomas-neemann
many thanks
mwlandolsi
Post by mwlandolsi »
Hello
could anyone explain to us how to fix this on mint 20.02 Cinnamon? I am not a Linux professional, I am just a simple user.
