A new series of 10 tutorials about Freecad CfdOf
Moderator: oliveroxtoby
techGuy
Re: A new series of 10 tutorials about Freecad CfdOf
Post by techGuy »
Great series. I just found the playlist the other day. I'm slowly making my way through them. Thanks for sharing them.
Raedchen_im_System
Post by Raedchen_im_System »
Tutorial #11: Simple Combustion with reactingFoam
I'm very excited to announce the latest release: I've recorded a new tutorial about reactingFoam. Methane and air react in a reactor vessel. The "conversion" of the solver from PimpleFoam to reactingFoam and the review of the results with Paraview is shown.
The hottest video I have ever recorded - temperatures above 2000 K were achieved.
The openFoam-tutorial that I used as a template for reactingFoam can be found here:
https://github.com/OpenFOAM/OpenFOAM-6
https://github.com/OpenFOAM/OpenFOAM-6/ ... lowFlame2D
Physics Model: transient, multiple phasis with chemical reactions, viscous, laminar flow
2D Model
Fluid: methane, air, water, carbon dioxide
Mesher: CfMesh
Solver Openfoam: reactingFoam
Link: https://youtu.be/TnPm4SVmdp0
Tutorial #11 Simple Combustion.FCStd
(31.87 KiB) Downloaded 139 times
thschrader
Post by thschrader »
Raedchen_im_System wrote: Sat Mar 04, 2023 11:11 pm ...
The hottest video I have ever recorded...
Great idea 8-)
Silent24
Post by Silent24 »
The super YouTube CFD videos bring me to this forum.
Well done.
Roland Kärnten
Raedchen_im_System
Tutorial #12: Simple Combustion with reactingFoam
In addition to my tutorial #11, I have recorded the next tutorial about explosive combustion using reactingFoam.
The original goal was to set up a simulation similar to combustion in an internal combustion engine. I was only partially able to do this due to the instability of reactingFoam. Nevertheless, I have shown that this type of combustion can be simulated with reactingFoam.
2D Model
Mesher: CfMesh
Link to the video: https://youtu.be/fvdZFCL6DHM
Tutorial#12_ExplosiveCombustion.FCStd
(28.96 KiB) Downloaded 98 times
Raedchen_im_System
Tutorial #13: Kelvin-Helmholtz instability with interFoam
I recorded a new tutorial about the Kelvin-Helmholtz instability. The resulting vortices are awesome.
For this simulation, I tried to use the dynamic refinement, but this leads to an error:
Error Dynamic Mesh Refinement.JPG (27.31 KiB) Viewed 16115 times
For this reason I used a very high-resolution mesh with an edge length of 0.5 mm. This increases the computing time on my computer to 2 hours and 44 minutes.
I took the experimental setup from the video by "Sixty Symbols" and the University of Nottingham, it's a video well worth seeing: https://youtu.be/mf_143gkKSQ
Physics Model: transient, multiple phasis, viscous, laminar flow
2D Model
Fluid:water / Sea Water
Mesher: CfMesh
Solver Openfoam: interFoam
Link to the video: https://youtu.be/w7ZKDwps1p4
Please find the model attached.
Lektion13_KelvinHelmholtzInstability.FCStd
(15.08 KiB) Downloaded 101 times
Raedchen_im_System
Tutorial #14: Simulation of Bubbles with InterFoam
In this video tutorial I tried to simulate air bubbles in water. The result is quite pleasing, but due to the fact that surface tension is not taken into account, the bubbles look different. In this tutorial, a material flow is used for the multiphase simulation with the Interfoam solver, i.e. there is an inlet and an outlet.
2D Model
Fluid:water / air
Mesher: CfMesh
Link to the video: https://youtu.be/6Z3n_nfo5AU
Lesson14_Interfoam_Bubbles.FCStd
(30.93 KiB) Downloaded 99 times
thschrader
Raedchen_im_System wrote: Tue Jun 20, 2023 5:58 pm The result is quite pleasing, but due to the fact that surface tension is not taken into account, the bubbles look different.
Thanks for the new video.
Surface-tension: you can edit the sigma-parameter in transportProperties.
I ran the sim using a finer mesh + surface-tension, to get a better resolution of the bubbles.
max cell size 0,25 mm, 200000 cells. But there are still bubbles (the blue ones) with a smeared out
alpha-air, so the resolution is still too coarse.
Raedchen_im_System
@thschrader : Thank you very much for your comments on the consideration of surface tensions in InterFoam! I linked your post in the description of my YouTube video.
soletto
Post by soletto »
Hallo,
can you tell me how to add surface tension?
Thank you in advance!
