It would be great to be able to unfold a sheet metal part without having to go through the FreeCAD GUI application!
You would have to modify the unfold.py script of the sheetmetal module so that it does not depend on the FreeCAD GUI module anymore.
And so, it would add a module available in headless version of FreeCAD
I already made an issue on the Github of the SheetMetal module : https://github.com/shaise/FreeCAD_SheetMetal/issues/227
Thank you in advance
Mod Edit: x-posted to the main SheetMetal forum thread: https://forum.freecadweb.org/viewtopic. ... 68#p591668
Feature request - Sheetmetal unfold without GUI
Re: Feature request - Sheetmetal unfold without GUI
Actually, I seed unfold script is highly dependant of GUI.Selection().
Is there any headless solution to select object or face ?
I think that Gui.Selection returns a list of objects, so if you can figure out which objects you're going to need, you can just substitute that list (or the code that produces it) for the Gui.Selection line. I'm a long way from an expert on this, so I would suggest posting this question in the "Python scripting and macros" forum, which is where those experts are most likely to see it.
For future reference, feature requests are supposed to be put in the Open Discussion forum. You're much, much more likely to get a response there–this forum is only used for announcements.
Any update on this ?
