Add official 3DMouse support
Re: Add official 3DMouse support
user5889 wrote: Fri Apr 22, 2022 2:38 pm The solution I want to propose makes use of a dynamic linking against the libraries already installed by the 3Dconnexion driver, so no need to consider to deploy them with the FreeCAD installer. The same approach has been recently used and accepted in KiCAD:
OK, this should be fine then. But I recommend to still keep the current solution for Windows because 3Dconnexion drops support for older devices. So, it's best to have a user parameter that allows to switch between the official and unofficial support.
