TechDraw ordinate dimensioning
Re: TechDraw ordinate dimensioning
Added the icons to the TechDraw menu and toolbar. Also inverted the colors on the icons and refined the design to match the existing icons.
The tool tips will still need to be refined.
Next I think I would need to dive into the commands behind the icons. I've been thinking that the the logic of the functions could be something like:
- Select the 0 node
- Select the nodes you want to dimension
- Click the icon
Tips and comments are more than appreciated.
Git link: https://github.com/kemes/FreeCAD_TechDr ... dimensions
- Select the 0 node
- Click the icon
- wandererfan
Took a quick peek at your branch - it looks good. You probably want to rebase your branch on the current master to save aggravation later.
We willl eventually need a feature derived from dimension that will remember the "nodes". We need to do this for chain dimensions too.
Ask questions if you get stuck on anything.
I suppose the first step would be finding out the selected nodes? right?
- wandererfan
Good place to start. If you're making the dimension from a set of vertices, something like this would work:
//get selected vertices from a DrawViewPart
auto selection = cmd->getSelection().getSelectionEx();
auto dvp = dynamic_cast<TechDraw::DrawViewPart*>(selection[0].getObject());
std::vector<std::string> vertexNames;
std::vector<std::string> subNames = selection[0].getSubNames();
for (auto& name : subNames) {
std::string type = DrawUtil::getGeomTypeFromName(name);
if (type == "Vertex") {
vertexNames.push_back(name):
- LVAeronautics
I see that it has been some time since this thread last saw any action. How is the ordinate dimensioning function coming along? Currently developing an aircraft, and having this capability would be extraordinarily helpful in ID'ing Station, Butt & Water Lines about the airframe, as well as dimensioning other items for the build.
Also, if there is a branch that has this capability, let me know, and since I am very new at the practice, if one of you can assist in showing me how to install said branch if one exists. Thanks!
"Testing leads to Failure, and Failure leads to Understanding" -Burt Rutan
- LVAeronautics
Downloaded what seems to be the latest/greatest; no ordinate dimensioning capability, unless I am not finding it. If I am wrong, please direct me to what I need. Thank you in advance!!Shalmeneser wrote: ↑Wed Mar 08, 2023 6:54 pm https://www.freecad.org/downloads.php > https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
Version: 0.21.0.32110 (Git)
Hash: a000dcf60af18f489fff48d29d7f2f4b2092483f
* AirPlaneDesign 0.4.0
* Assembly4 0.12.6
* CfdOF 1.21.6
* CurvedShapes 1.0.4
* Curves 0.6.8
* Defeaturing 1.2.0
* Estimate 0.1.2
* ExplodedAssembly 0.2.61
* fasteners 0.4.54
* FeedsAndSpeeds 0.5.0
* FEMbyGEN 1.2.0
* FEM_FrontISTR 0.1.0
* freecad.gears 1.0.0
* lattice2 1.0.0
* LCInterlocking
* Render 2023.2.2
* Rocket 2.8.6
* sheetmetal 0.2.61
* Ship 2022.4.11
Unfortunately, it's not available in master. There's even no open PR for it yet. It's only available in kemes' GitHub branch but he hasn't be active since the fall of 2023.
@kemes Any chance for PR in master or is this project abandoned ?
- LVAeronautics
That is unfortunate. Ordinate dimensioning is a big must-have in the aero and sheet metal worlds. But if @kemes has a product, I just need to know how to download it. Other than that, FreeCAD is amazing!
You can build FreeCAD from his branch. Instructions are available on the FreeCAD wiki, depending on the OS.LVAeronautics wrote: ↑Wed Mar 08, 2023 10:38 pm But if @kemes has a product, I just need to know how to download it.
