TechDraw ordinate dimensioning
wandererfan
Re: TechDraw ordinate dimensioning
Post by wandererfan »
kemes wrote: Thu Mar 24, 2022 1:17 pm @wandererfan I would like to contribute to the development of this function. I don't have any prior experience in FC dev. Where would you suggest to look at to get things rolling? A similar function etc?
That's great! There is always more work than there are workers.
You could start with these files:
src/Mod/TechDraw/App/DrawViewDimension.cpp is the dimension DocumentObject
src/Mod/TechDraw/Gui/QGIViewDimension.cpp does the drawing.
src/Mod/TechDraw/Gui/CommandCreateDims.cpp handles the buttons and commands.
src/Mod/TechDraw/Gui/ViewProviderDimension.cpp bridges the App side to the Gui side.
You might want to look at Gui/CommandExtensionDims.cpp which has functions for chain dimensions, etc.
The biggest hurdle to overcome is that the existing dimensions all refer to 1 edge or 2 vertices and have a single value. Ordinate dimensions are going to need to refer to n vertices and produce n-1 values.
Feel free to come back with questions.
PS. were you thinking about doing this in C++ or Python? If you choose Python, we'll have to expose more of the inner workings of Dimensions to Python. Probably not a bad thing in the long run.
kemes
Post by kemes »
wandererfan wrote: Thu Mar 24, 2022 1:43 pm That's great! There is always more work than there are workers.
Thanks for the intro. I will have a look into these files. I don't have any prior experience in C++ but definitely would want to learn it. My experience lies in C (embedded systems), Python and Web related technologies.
I'll next try to understand the current content (the files you mentioned) and I'll get back to you afterwards. I'll probably need guidance on defining the flow, in which order should things be done. I have a lot to learn.
kemes
Post by kemes »
kemes
Post by kemes »
Started easy by adding the icons for Vert and Horiz Ordinate Dimensions -functions. Next would be adding them to the toolbar. Baby steps :lol:
commit fede3f8c5faa04816f23fa5835cc3b56972eabd8
@kemes, do you mind creating a new git branch on your fork (so you're not committing changes to the 'master' branch). So when you make a PR you're doing it from your own branch against master.
kemes
Post by kemes »
Kunda1 wrote: Sun Apr 03, 2022 8:33 pm @kemes, do you mind creating a new git branch on your fork (so you're not committing changes to the 'master' branch). So when you make a PR you're doing it from your own branch against master.
I was about to ask about this. Thanks for the guidance, will create a new branch.
kemes
Post by kemes »
Created a branch called techdraw_ordinate_dimensions
Well played 8-)
wandererfan
kemes wrote: Sun Apr 03, 2022 8:16 pm Started easy by adding the icons for Vert and Horiz Ordinate Dimensions -functions. Next would be adding them to the toolbar. Baby steps :lol:
Good place to start, nothing wrong with baby steps. You could probably make a "do nothing" command that would put your new icons onto the toolbar as a next step. See CommandExtensionDims.cpp and Workbench.cpp.
Very minor detail, but the icons look like they were saved as "Inkscape svg". A better choice is to save as "plain svg".
kemes
Post by kemes »
wandererfan wrote: Tue Apr 05, 2022 1:19 pm Good place to start, nothing wrong with baby steps. You could probably make a "do nothing" command that would put your new icons onto the toolbar as a next step. See CommandExtensionDims.cpp and Workbench.cpp.
Thank you for the tips!
All the icons from the TechDrawTools (now used in TechDraw) seems to be Inkscape svg. I followed this.
