PR 6339: Preference Packs: Add revert to backup option
chennes
Post by chennes »
https://github.com/FreeCAD/FreeCAD/pull/6339
When you apply a preference pack, a backup of your old user.cfg file is stored for a week, in case you change your mind, or discover a problem with the new settings. This simple GUI element allows you to restore to that backed-up config file directly from within FreeCAD, without needing to dig through your filesystem.
Screenshot 2022-02-13 201541.png (68.9 KiB) Viewed 7074 times
Screenshot 2022-02-13 201613.png (18.13 KiB) Viewed 7074 times
Chris Hennes
Pioneer Library System
Re: PR 6339: Preference Packs: Add revert to backup option
Great idea! Looking forward to trying this out
llll
Post by llll »
I "lost" the Dark sheet theme, "preference pack", how is it reinstated manually?
chennes
Post by chennes »
If you mean the "Behave-dark" pack seen in my screenshot above, it's installed using the Addon Manager -- if you switch to showing only Preference Packs there it will be at the top of the list. And the bottom ;)
Chris Hennes
chennes wrote: Mon Apr 04, 2022 2:28 am it will be at the top of the list. And the bottom ;)
:lol:
