[Sketcher] Distance to circle
Re: [Sketcher] Distance to circle
onekk wrote: Tue Mar 21, 2023 10:20 am Has the problem with build system has been solved?
See viewtopic.php?t=76795 .
tldr: build system still broken, the "new" builds that are uploaded are just the same reuploaded.
Piero69
Post by Piero69 »
chrisb wrote: Tue Mar 21, 2023 9:29 am
Piero69 wrote: Tue Mar 21, 2023 6:28 am great! unfortunately since over a month a new build is a chimera :D
I have just seen that the revision number hasn't changed, but it seems to have been updated yesterday. My version dates from the 4th of march and has revision number 32198. The same was published yesterday.
yes, only the date is changing but the build is always the same, moreover the version for py3.10 is still older ... 31197 dated 16 February
I just tested circle to circle distance. It works well!
Canit be extended to arcs as well? Like tangency or point-on-object it should work as if it was a full circle, so hopefully it is not too much effort. :mrgreen:
flachyjoe wrote: Wed Mar 15, 2023 8:43 pm I plane to write line to circle and point to circle too.
Do you plan to integrate this into 0.21? I want to include this new constraint into my sketcher lecture, and it would of course be less effort, if I could change it all at once.
flachyjoe
Post by flachyjoe »
Hi @chrisb ,
Distance to Arc is here : https://github.com/FreeCAD/FreeCAD/pull/9166
and Circle to Line here : https://github.com/FreeCAD/FreeCAD/pull/9044
- Flachy Joe -
Thanks @flachyjoe, I will describe it in the document hoping that it will make it into 0.21.
NewJoker
Post by NewJoker »
Hi @flachyjoe,
I've noticed that the newly implemented circle to circle distance constraint doesn't work when one of the circles is an external geometry:
circle to circle 'error.PNG (57.24 KiB) Viewed 1363 times
Is that a known limitation ?
flachyjoe
Post by flachyjoe »
NewJoker wrote: Mon Jun 19, 2023 1:02 pm Is that a known limitation ?
No, it's a bug! :?
EDIT: @NewJoker FYI the fix is in progress.
EDIT 2: the fix is now merged.
- Flachy Joe -
