Screw Maker
lsmod
Re: Screw Maker
Post by lsmod »
ulrich1a wrote:
lsmod wrote:but i need more to have a thread in a solid object.
Do you need a inner thread in a solid object in order to screw something in, or do you want something like a threaded bolt on a solid object?
Mostly i need a inner thread in a solid object in order to screw something in.
Printing a complete screw is a nice 3D demonstration, but in reality you can buy a ready one.
When you construct something it is really needed to have the possiblity to screw something together with a normal screw.
lsmod
Re: Screw Maker
Post by lsmod »
ulrich1a wrote:This is on my todo-list.
That's perfect!
ulrich1a wrote:So ScrewMaker should than provide a screwtap to cut a thread into a solid. Unfortunately the progress is slowly, so more in months than days.
I have some code that generates threads faster. Unfortunately it breaks some screws. So I need to fix this first, before publishing it.
Do you mean it needs month to cut a thread? :D
When the script is working slow but perfect this is not really a problem.
You get time to drink coffee ...
But i never get it done so fast when i should do it for myself manually. ;)
makerdog
Re: Screw Maker
Post by makerdog »
lsmod wrote: Mostly i need a inner thread in a solid object in order to screw something in.
Why not create the screw and then use the boolean cut operation to create the inner threads of the solid object?
lsmod
Re: Screw Maker
Post by lsmod »
makerdog wrote:Why not create the screw and then use the boolean cut operation to create the inner threads of the solid object?
Can you explain how to do this for a beginner please?
Thanks!
popsmike
Re: Screw Maker
Post by popsmike »
I'm a newbie to this type of program and was wondering if anyone could tell me how to change the settings for this macro (If I am indeed allowed to that is).
I am after inserting a new screw model based on one of the others. Or maybe this is a request to the creator...
I am trying to make a 3.5mm ISO2010 : Slotted raised Countersunk head screw for use in electrical fittings ie. a socket or light switch as this is the standard size for these.
I am sorry if I am imposing on something, I don't mean to sorry.
Mike
cox
Re: Screw Maker
Post by cox »
Welcome to the FreeCAD forum popsmike,
Just out of curiosity i googled 3.5 mm ISO2010 and I could not find any on exactly 3.5 mm.
According to some tables I found 2.5mm 3mm 4mm
Do you have spec. on it?
http://www.globalfastener.com/standards ... _2991.html
Need help? Feel free to ask, but please read the guidelines first
ulrich1a
Re: Screw Maker
Post by ulrich1a »
cox wrote:Just out of curiosity i googled 3.5 mm ISO2010 and I could not find any on exactly 3.5 mm.
Those screws with M3.5 are indeed defined. Have a look here at the indian version of the corresponding ISO-standard: https://law.resource.org/pub/in/bis/S01 ... 1.2005.pdf
The standard says: "should be avoided if possible"
popsmike wrote:I'm a newbie to this type of program and was wondering if anyone could tell me how to change the settings for this macro (If I am indeed allowed to that is).
The macro is licensed under LGPL 2.2. So you are allowed to change the code.
I enabled this diameter in the menu. See here for a version of the macro with M3.5-screws.
Ulrich
screw_maker1_7b.py.zip
(18.86 KiB) Downloaded 130 times
cox
Re: Screw Maker
Post by cox »
ulrich1a wrote:indian version of the corresponding ISO-standard
Thanks, ulricha
I like the cover-page of the Indian ISO document a lot. Put a smile on my hart:-)
shaise
Re: Screw Maker
Post by shaise »
Hi Ulrich
I must say I use FreeCAD for about 3 years and until recently did not bother to look for extensions. Only to find now there are great extensions out there that could have saved me lots of time. After I saw your very nice Unfold code, I now stumbled on your yet another great macro - the Screw Maker.
I would like your permission to translate your macro to a new workbench: Fasteners. This way screw creation will be easy, and also parametric, and maybe even follow other part's geometry. It will look something like this:
Thanks again!
shai
microelly2
Re: Screw Maker
Post by microelly2 »
shaise wrote: ... to a new workbench: Fasteners.
Hello shai
Let me know when your workbench is comming up.
