[FIXED] Security Advisory: DWG import/export with ODA file converter
eldstal
Post by eldstal »
Summary
When FreeCAD is configured to use the ODA file converter, a DWG file with a crafted filename is able to trigger a Remote Code Execution vulnerability.
A ticket is open in the bug tracker, since I'm quite certain this needs patching.
Vulnerable Version
FreeCAD_weekly-builds-26683 and older
Steps to reproduce
1. Configure DWG import using the ODA file converter
2. Create and import the proof-of-concept file:
The PoC is an empty file, which can be created on a linux system using the following command:
touch '";galculator;ls ".dwg'
Change `galculator` to any shell command you wish to execute.
3. `galculator` is launched by FreeCAD during DWG import.
Cause
The first parameter to subprocess.call() at importDWG.py:225 contains unsanitized user input (the filename of the DWG file). By prematurely closing the quotes, the executed command line can be modified by an attacker.
Impact
Arbitrary code execution
Proposed Mitigation
`subprocess.Popen()` is a better option to invoke the converter, since the binary can be specified by FreeCAD separately from arguments. In addition, this bypasses the system shell.
A similar flaw is present in the DWG export using ODA file converter, but this is less serious as the vector is the output filename. To verify this, try loading any project and export to a filename on one of these forms:
`galculator`.dwg
$(galculator).dwg
I'm a FreeCAD user, should I be worried?
This vulnerability is only exploitable by the filename of opened files. Therefore, be wary of importing files with strange characters (quotes, backslashes, backticks (`), dollar signs, that sort of thing) in their filenames.
Version information
OS: Arch Linux (i3/i3)
Version: 0.20.26683 (Git) AppImage
Branch: (HEAD detached at 0388fbc)
Hash: 0388fbc98d49d874fb341b9037a743bc691d501f
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
dwg_oda_rce.zip
The proof-of-concept DWG file which runs galculator.
(192 Bytes) Downloaded 44 times
Re: Security Advisory: DWG import with ODA file converter
Moved to Developers corner subforum
Re: Security Advisory: DWG import/export with ODA file converter
A similar issue from two years ago: https://forum.freecadweb.org/viewtopic.php?f=3&t=39683
Since I don't have the Teigha converter installed I simulate it with this simple Python script
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import sys
print (sys.argv)
that is located under /tmp/teigha
Now the issue can be reduced to this Python snippet:
import subprocess
teigha="/tmp/teigha"
indir="indir"
outdir="outdir"
basename='";galculator;ls ".dwg'
cmdline = '"%s" "%s" "%s" "ACAD2000" "DXF" "0" "1" "%s"' % (teigha, indir, outdir, basename)
subprocess.call(cmdline, shell=True)
This will start the application galculator.
There are several ways to escape the string cmdline. In a SO article the built-in function repr() was suggested:
subprocess.call(repr(cmdline), shell=True)
This will do nothing and returns the error code 127. When FreeCAD is started from the terminal you will get this error message:
/bin/sh: 1: "/tmp/teigha" "indir" "outdir" "ACAD2000" "DXF" "0" "1" "";galculator;ls ".dwg": not found
So, this "solution" can be ignored.
An alternative is suggested here that uses pipes.quote():
import pipes
commandargs = [teigha, indir, outdir, "ACAD2000", "DXF", "0", "1", basename]
cmdline = " ".join(map(pipes.quote, commandargs))
This works as expected. subprocess.call() returns 0 and the expected output in the terminal is:
['/tmp/teigha', 'indir', 'outdir', 'ACAD2000', 'DXF', '0', '1', '";galculator;ls ".dwg']
Since subprocess.call() also accepts a list as program arguments there is no need to create a string and instead the list can be directly passed:
cmdline = [teigha, indir, outdir, "ACAD2000", "DXF", "0", "1", basename]
subprocess.call(cmdline)
or with the more modern Popen
proc=subprocess.Popen(cmdline)
proc.wait()
The last two snippets only work correctly when "shell=True" is not set. And according to https://docs.python.org/3/library/subpr ... iderations this should be avoided anyway.
chennes
Post by chennes »
That last snippet is how the other DWG converters are called, isn't it?
Chris Hennes
Pioneer Library System
chennes wrote: Tue Dec 28, 2021 2:44 pm That last snippet is how the other DWG converters are called, isn't it?
Yes, but instead of wait() they call communicate().
eldstal
Re: [FIXED] Security Advisory: DWG import/export with ODA file converter
Post by eldstal »
Good job getting at this so quickly!
Thanks, have a happy new year and good luck with the 0.20 release!
eldstal
Post by eldstal »
This vulnerability has been assigned CVE-2021-45844.
wmayer wrote: Tue Dec 28, 2021 3:17 pm git commit 1742d7ff82
Hi wmayer, did this get backported? (or in the works?)
