Addon Manager Redesign 2021
Re: Addon Manager Redesign 2021
That's clever, I like it, I confirmed that the user Mod folder has precedence by copying the built-in addon there and adding
FreeCAD.Console.PrintWarning("addon manager loaded from user Mod folder")
to the addon manager command Activated() function.
rynn
Post by rynn »
Timeout-Problem?
I have the problem that Addon-Manager stalls after about 50 % or so. At that time it has a lot of open connections to github (lb-140-82-121-4-fra.github.com and cdn-185-199-109-133.github.com).
tcp       140.82.121.4:443        VERBUNDEN   192258/freecad
tcp       185.199.109.133:443     VERBUNDEN   192258/freecad
tcp       140.82.121.5:443        VERBUNDEN   192258/freecad
tcp       104.248.36.231:443      VERBUNDEN   192258/freecad
After some time this connections all vanish, but Addon-Manager still hangs.
As the status-line seems to by asynchron and there is no log (?) I have no idea what requests this are.
My assumption is, that this connections timeout and addon-manager can not handle this.
This may not be a problem in developed countries, but here in germany internet is not the best.
leoheck
Post by leoheck »
Hello there, I have some humble questions about the current version fo the Addon Manager.
1. Why this view has SO HUGE titles? It is bigger than anything on my computer, which means it is barely impossible to read.
2. Can we can a List with Columns? Maybe 2 Columns to start with (Title | Description) but maybe ( Checkbox | Title | Description ) would be nice since you can select multiples lines at once to perform the action Install/Remove/Upgrade
3. I have 3 Updates to do. Where do I check which files are, before doing the update? How do I select which one I want to update?
4. It looks like the Progress Bar never ends. It never reaches 100%. For me, it goes until on 3/5, I think.
5. Stop button at the end of the progress bar does not do anything.
leoheck wrote: Mon Oct 03, 2022 7:55 pm 4. It looks like the Progress Bar never ends. It never reaches 100%. For me, it goes until on 3/5, I think.
I think @chennes fixed this in git commit 9b4183581f6. I'm waiting for the snap edge to finish to test this fix
(https://github.com/FreeCAD/FreeCAD-snap ... 3176650717)
Edit: fix wrong reference
Edit2: I reported this earlier in https://forum.freecadweb.org/viewtopic.php?f=8&t=72310
leoheck
Post by leoheck »
Oh, nice. Thanks.
chennes
Post by chennes »
leoheck wrote: Mon Oct 03, 2022 7:55 pm 1. Why this view has SO HUGE titles? It is bigger than anything on my computer, which means it is barely impossible to read.
Did you have a look at "Compact Mode"? It's the first button in the upper left corner, and may be more to your liking. The larger lines make more sense if you decide to download the Macros, so that the icons all get populated and you get the descriptive text.
The easiest way is to change the "Status" dropdown to "Update available". Then you can update one at a time by clicking on them, or do all updates with the Update All button.
This should be resolved now, but if it's not please let me know.
I'll look into it, thanks for the report.
Chris Hennes
Pioneer Library System
leoheck
Post by leoheck »
Compact mode, sure, the one I use. And this is messed up too. To busy. Completely hard to read. Having columns could also improve this one a bit.
But those HUGE words are bigger than anything inside the computer. They are bigger than the words in the outdoors I can se from my window. This should be fixed. This is a huge bug.
Fonts should have a similar size other wise they cannot be seen even if they are big.
At my work, the number of the building is the size of a Human Being In the ground level, close to the door. There is not a single driver that finds it because people are looking for building numbers with the size of 1/4 of a standard A4 paper, at most.
I just want to take a moment and thank all the work @chennes is doing on this beast of a task! Amazing contribution to improving FreeCAD UI/UX!
Kunda1 wrote: Wed Oct 05, 2022 11:23 am I just want to take a moment and thank all the work @chennes is doing on this beast of a task! Amazing contribution to improving FreeCAD UI/UX!
@chennes is working hard on AddOn Manager and also in some other UI/UX tasks, he deserve many thanks, (Sorry I can't be in Brussels to pay you a beer or two :D).
Doing thing not so easy as criticize ;).
Many Thanks @chennes.
Kind Regards
easyw-fc
Post by easyw-fc »
onekk wrote: Wed Oct 05, 2022 4:03 pm Doing thing not so easy as criticize ;).
+1 :D
