Addon Manager Redesign 2021
Re: Addon Manager Redesign 2021
Yeah, the cache strategy needs a little work, right now it's an all-or-nothing update, so it's not possible to update the contents of just a single addon. It's dumb.
I cannot disable any WB
here the error:
and FC info
here the error:
File "C:\FreeCAD\Mod\AddonManager\package_details.py", line 670, in disable_clicked
self.repo.disable()
File "C:\FreeCAD\Mod\AddonManager\Addon.py", line 524, in disable
stopfile = os.path.join(mod_directory, self.name, "ADDON_DISABLED")
NameError: name 'mod_directory' is not defined
OS: Windows 10 Version 1909
Version: 0.21.30305 (Git)
Hash: 5ffc2e10b69971e2cdcd798c4deacf44d407fd77
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Sorry about that: should be fixed by git commit 6347f90b1532ffe8b9018f825a7bc713b2250e26
thanks for your work on the new AMchennes wrote: ↑Fri Sep 09, 2022 6:06 pm Sorry about that: should be fixed by git commit 6347f90b1532ffe8b9018f825a7bc713b2250e26
Maybe a stupid question:
dependencies installe by a package, like gmsh for GDML WB are left over when uninstalling the package that has pulled them.
There is a way to check if there are some "not needed" external packages installed?
I haven’t written the code to do it, but in principle that is possible. You could basically loop over all the installed Addons and ask for their dependencies: the set you get out is the ones still needed.
- adrianinsaval
Is it possible to install dependencies after the fact? Or to reinstall/update after an upgrade of python for example? It might also be a good idea to have the directory for those dependencies be specific to the python version since it's possible to have multiple versions installed at the same time (on windows conda builds and libpack, on Linux appimage/conda and distro package) and I think some pip packages are supposed to be specific to the version of python you are running. All of this would be nice but are low priority.
Hello.
I've noted today this strange behaviour:
backup directory created by AddOn Manager are visualized as installed WB.
It is intended, or it is glitch in AddOn Manager?
OS: Artix Linux (openbox)
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: Italian/Italy (it_IT)
* Curves.backup1662281788.2751102 0.4.1
* fcgear.backup1662281841.5151978 1.0.0
* test_wb
* fcgear 1.0.0
* Curves 0.5.7
* Help.backup1662281850.737508 1.0.3
* Help 1.0.3
Not a glitch in the Addon Manager so much as naïveté on the part of the code that lists out the Addons, which was written before the backup code was added. I'll have to adjust it so it doesn't show those. And I think the backup code is probably not aggressive enough about deleting those backups when they aren't needed anymore.
quote=chennes user_id=11959] ! [/quote]
Probably a silly question, but I can't find a proper answer or most probably I could not see the informations in the documentation:
a .gitmodules "stanza" that resemble like this:
submodule
will contain the "WBName" that is the name shown as a name in the AddOn Manager?
path
will make a subdir named "WBdirName" in the /Mod/ dir
url
is the url of the github repo, but with or without the .git
as example
that is copied simple from the url bar of a webbrowser is good, as I find mixed writings in the .gitmodules like:
branch
Ok you have already explained that is the branch name on the git repo from which the AddOn Manager should "clone" the file to be put in /Mod/ dir
I have guessed correctly or something is wrong?
TIA and Regards
Sorry for the multiple edits, but my sight is not good, or probably the webbrowser minimun font size is too small for my old eyes.
[submodule "WBName"]
path = WBdirName
url = https://github.com/...
branch = main
path
url
as example
https://github.com/KeithSloan/OpenSCAD_Alt_Import
[submodule "ArchTextures"]
path = ArchTextures
url = https://github.com/furti/FreeCAD-ArchTextures
[submodule "assembly2"]
path = assembly2
url = https://github.com/hamish2014/FreeCAD_assembly2.git
branch
TIA and Regards
