Thanks testing. Can you also try latest 0.20_pre ?
Importing a IFC file and FC crashes
Re: Importing a IFC file and FC crashes
Better back to testing : QUA_EST_BLE_NAO_OFICIAL.ifc
Crash with -
OK with -
FreeCAD_0.19-24291-Linux-Conda_glibc2.12-x86_64.AppImage
All tested on Fedora 34 -
Crash with -
FreeCAD_0.19.3-Linux-Conda_glibc2.12-x86_64.AppImage
OK with -
Created a log until crashes, extracted the last few lines before crash
Msg: 649Msg: Msg: /Msg: Msg: 1199Msg: Msg: object #8105Msg: Msg: :Msg: Msg: IfcFastenerMsg: Msg: layer Msg: Msg: 0 Msg: Msg: foundMsg: Msg: IfcFastenerMsg: Msg: (arch)Msg: Msg: 11k Msg: Msg: : Weld029 Msg: Msg: 1 solidsMsg: Msg: Msg:
Msg: 650Msg: Msg: /Msg: Msg: 1199Msg: Msg: object #8120Msg: Msg: :Msg: Msg: IfcPlateMsg: Msg: layer Msg: Msg: 1 Phase 1Msg: Msg: foundMsg: Msg: IfcPlateMsg: Msg: (arch)Msg: Msg: 2k Msg: Msg: : CHAPA245 Msg: Msg: Msg: Msg: Msg:
Msg: 651Msg: Msg: /Msg: Msg: 1199Msg: Msg: object #8159Msg: Msg: :Msg: Msg: IfcPlateMsg: Msg: layer Msg: Msg: 1 Phase 1Msg: Msg: foundMsg: Msg: IfcPlateMsg: Msg: (arch)Msg: Err: Program received signal SIGSEGV, Segmentation fault.
Crash log on importing the Villa Savoye model (1F only)
- thomas-neemann
here it worked no with 0.20.26155 but with:
Version: 0.19.24291 (Git) AppImage
Branch: (HEAD detached at 0.19.2)
Python version: 3.8.8
Qt version: 5.12.9
it is ok
- thomas-neemann
this is a nice example of how an ifc file shouldn't be. with welds, screws and washers. this relatively small project creates files that are very slow and complicated to import. because ifc files are not used as a data exchange format in the bim process, but only for referencing, a fast dae file is sufficient. converted from ifc
OS: macOS 10.15
Version: 0.20.26559 (Git)
Branch: adaptive_dicretize_bugfix
Hash: 3507f7fc0d81b5281f4194220dc890952320be29
Python version: 3.10.8
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Germany (en_DE)
still crashes
the issue seems to be fixed a similar way in the latest git source (just checked)
https://www.soil-parts.at/downloads/
https://www.soil-parts.at/app/download/ ... 1637736812
that's what I did for now but certainly at another side it probably expects a nullptr coming out from propset
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
still crashes
0, debug map time is 2022-10-02 05:59:04.000000000) since this executable was linked, file will be ignored
* thread #1, name = 'CrBrowserMain', queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0)
* frame #0: 0x00007fff6dceae52 libsystem_platform.dylib`_platform_strlen + 18
frame #1: 0x00000001000101e5 FreeCAD`std::__1::char_traits<char>::length(__s=0x0000000000000000) at __string:253:53
frame #2: 0x00000001052eb149 libFreeCADApp.dylib`std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >::basic_string<std::nullptr_t>(this="%\x9es\x01\0\0\0 >???\0\0*", __s=0x0000000000000000) at string:819:19
frame #3: 0x00000001052d681d libFreeCADApp.dylib`std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >::basic_string<std::nullptr_t>(this="%\x9es\x01\0\0\0 >???\0\0*", __s=0x0000000000000000) at string:817:88
frame #4: 0x00000001052e5f43 libFreeCADApp.dylib`App::ObjectIdentifier::access(this=0x00007ffeefbf4070, obj=0x0000000132d07800, prop=0x0000000000000000, propName=0x0000000000000000) const::$_0::operator()(App::DocumentObject*, App::Property*, char const*) const at ObjectIdentifier.cpp:1686:28 <<<<------
if(propset.size()!=1 || propset.begin()->size()) {
if(!propName)
propset.clear();
>> if (propName == nullptr)
>> propName = strdup("");
propset.insert(propName);
- thomas-neemann
here it works
Version: 0.21.0.32985 (Git) AppImage
Hash: 5cd377f931312ede305e4c764ba2028b20eaacfd
* Curves 0.6.8
* fasteners 0.4.56
it also works here, with the patch. Latest Git Sourcecode is already fixed as mentioned.
