FreeCAD 0.20.2 on Debian Bullseye/Intel : graphic issue
ljoets
Post by ljoets »
I use FreeCAD 0.19 from official Debian Bullseye repo on my laptop and I have an display issue (FreeCAD 0.18 worked great on it).
Capture d’écran de 2021-10-26 18-49-42.png (29.56 KiB) Viewed 3016 times
Here is my Intel Graphic card info :
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
What could I do/test ?
Thanks
[edit] I juste tested appimage and it's working well :?
ljoets
Re: FreeCAD 019 on Debian Bullseye/Intel : graphic issue
Post by ljoets »
I have the same problem on Debian 11 with latest 20.2 appimage :-(
this is usually a dpi issue, check your font dpi settings
ljoets
Post by ljoets »
Thanks for that idea. Would you know how to find these settings in Debian Gnome ?
However :
FreeCAD_0.19.3-Linux-Conda_glibc2.12-x86_64.Appimage is ok
FreeCAD_0.20-1-2022-08-20-conda-Linux-x86_64-py310.AppImage is not ok
FreeCAD_0.20.2-2022-12-27-conda-Linux-x86_64-py310.AppImage is not ok
So I'm not sure that the problem is on the OS.
holm
Re: FreeCAD 0.20.2 on Debian Bullseye/Intel : graphic issue
Post by holm »
...no, it is not.
I'm using FreeBSD where FreeCAD is built out of the sources in a so called "port".
Since months now I'm looking for an version that works, and the last 5,6 tries are all building a FreeCAD with this Display Bug.
The Xserver here is an Nvidia blob that's working fine so far, no other programs including Qcad or Kicad have such problems.
This are some lines of output from xdpyinfo:
screen #0:
dimensions: 3840x1200 pixels (1049x321 millimeters)
resolution: 93x95 dots per inch
depths (7): 24, 1, 4, 8, 15, 16, 32
root window id: 0x305
depth of root window: 24 planes
number of colormaps: minimum 1, maximum 1
default colormap: 0x20
default number of colormap cells: 256
What's wrong here regarding a "dpi issue"?
That's a virtual desktop containing two displays. If it where a dpi issue, I would expect distorted display window regarding height/width, but no incomplete icons or Text entries.. so what is the problem here? (please?)
Regards,
Holm
bambuko
Post by bambuko »
ljoets wrote: Sun Jan 01, 2023 2:58 pm I have the same problem on Debian 11 with latest 20.2 appimage :-(
that's what I use with no problem at all:
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.21.0.31709 (Git) AppImage
Hash: e188802ca6997d2564e7570ab648462e6a059f87
  * ToolViewReverse_ToolBar
  * DynamicData 2.46.0
  * sheetmetal 0.2.49
  * Assembly3 0.11.3
  * fasteners 0.3.40
  * ThreadProfile 1.81.0
  * Manipulator 1.4.3
and (some) system info:
System:    Kernel: 6.0.0-6mx-amd64 [6.0.12-1~mx21+1] x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-6.0.0-6mx-amd64
           root=UUID=<filter> ro quiet splash
           Desktop: KDE Plasma 5.20.5 wm: kwin_x11 vt: 7 dm: SDDM
           Distro: MX-21.3_KDE_x64 Wildflower January 15  2023
           base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: Desktop Mobo: Gigabyte model: Z97M-D3H v: x.x serial: <filter>
           BIOS: American Megatrends v: F8 date: 09/18/2015
CPU:       Info: Quad Core model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell family: 6
           model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28000
           Speed: 1420 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1300 2: 1200 3: 1100
           4: 1300
           Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
           Type: mds mitigation: Clear CPU buffers; SMT disabled
           Type: meltdown mitigation: PTI
           Type: mmio_stale_data status: Unknown: No mitigations
           Type: retbleed status: Not affected
           Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
           Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
           Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: disabled,
           RSB filling, PBRSB-eIBRS: Not affected
           Type: srbds mitigation: Microcode
           Type: tsx_async_abort status: Not affected
Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
           vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
           class-ID: 0300
           Device-2: NVIDIA TU116 [GeForce GTX 1650 SUPER] driver: nouveau v: kernel
           bus-ID: 01:00.0 chip-ID: 10de:2187 class-ID: 0300
           Display: x11 server: X.Org 1.20.14 compositor: kwin_x11 driver: loaded: modesetting
           unloaded: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
           s-diag: 777mm (30.6")
           Monitor-1: DVI-D-1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
           diag: 685mm (27")
           OpenGL: renderer: NV168 v: 4.3 Mesa 22.0.5 direct render: Yes
Usually the problems could be related to Mesa library and old Intel architectures, probably before 5th or 6th generation.
I'm using a 2nd generation i3 and on Arch Linux to avoid problems, even with Firefox I've been forced to install a specifically build Mesa Libs for "older architecture".
Hope it helps.
holm
Post by holm »
..at least in my case that wouldn't help, I'm using an AMD Ryzen 5 and as far as I know there is no build switch for "older architectures" on my FreeBSD13.1-stable amd64 system. I think I've rebuild mesa several times since I'm aware of this bug.
holm@trollo:~ $ pkg info -a|grep mesa
libosmesa-21.3.8 Off-Screen Mesa implementation of the OpenGL API
mesa-demos-8.4.0_3 OpenGL demos distributed with Mesa
mesa-dri-22.3.5 OpenGL hardware acceleration drivers for DRI2+
mesa-libs-22.3.5 OpenGL libraries that support GLX and EGL clients
holm@trollo:~ $
Regards,
Holm
akredd
Post by akredd »
Hello
I use realthunder's Appimage for ASM3 and it runs fine.
OS: Ubuntu 22.04.2 LTS (MATE/mate)
Version: 2023.131.26244 +5365 (Git) AppImage
Branch: LinkDaily
Hash: 73c4ca254c5de8849d104973482e98399fb24863
Python version: 3.10.8
Qt version: 5.15.4
Coin version: 4.0.1
OCC version: 7.6.3
The FreeCAD and FreeCAD-Daily Package have the problems as mentioned.
For freeCAD-Daily:
Version: 0.21.
Branch: unknown
Hash: 1faf86c3da12c1712e1d5ec015721d9aa02f8672
Python 3.10.4, Qt 5.15.3, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.1
  * fcgear 1.0.0
  * GDTplus 0.1.0
  * fasteners 0.4.54
  * workfeature
  * Curves 0.6.6
  * lattice2 1.0.0
  * Defeaturing 1.2.0
  * symbols_library
  * Ship 2022.4.11
  * workfeature-macro
  * MRail 0.1.0
  * sheetmetal 0.2.61
  * Plot 2022.4.17
  * nurbs
  * Trails 2022.1.0
  * A2plus 0.4.60i
  * CurvedShapes 1.0.4
  * slic3r-tools
  * 3DfindIT 1.2.0
  * Manipulator 1.5.0
  * retr3d
For FreeCAD:
Version: 0.20.1.
Branch: unknown
Hash: 22f524c0c755003c12234fab1bad6a9f696b661a
Python 3.10.6, Qt 5.15.3, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.1
  * fcgear 1.0.0
  * GDTplus 0.1.0
  * fasteners 0.4.54
  * workfeature
  * Curves 0.6.6
  * lattice2 1.0.0
  * Defeaturing 1.2.0
  * symbols_library
  * Ship 2022.4.11
  * workfeature-macro
  * MRail 0.1.0
  * sheetmetal 0.2.61
  * Plot 2022.4.17
  * nurbs
  * Trails 2022.1.0
  * A2plus 0.4.60i
  * slic3r-tools
  * 3DfindIT 1.2.0
  * Manipulator 1.5.0
  * retr3d
So I am in doubt that it should be a Problem with libraries or OS. Are there any other hints to solve this? It would be nice because I like to try the new possibilities in TechDraw (looks very interesting in the wiki).
Andreas
have you tried setting your font dpi settings to 96? this is usually the problem
