Change parent but keep position.
How can I change parent of a body or a part but keep global location during change.
Re: Change parent but keep position.
What is parent ?
It is a parent element of a body in hierarchy.
When I drag body on top of a part, the part becomes parent of a body.
So it's an Std_Part object.
AFAIK you have to use Python console.
Let's say that you have an object 'OBJECT' and you want to drag it into a container 'PART' :
## Run the 2 below lines before mowing object
pl_orig = App.ActiveDocument.OBJECT.getGlobalPlacement()
pl_part = App.ActiveDocument.PART.getGlobalPlacement()
## Now drag OBJECT into Part before running following lines
App.ActiveDocument.OBJECT.Placement = pl_part.inverse().multiply(pl_orig)
Thank you. This is quite convoluted but at least I have learned how to use python console.openBrain wrote: ↑Wed Oct 13, 2021 3:20 pm So it's an Std_Part object.
Let's say that you have an object 'OBJECT' and you want to drag it into a container 'PART' :Code: Select all
## Run the 2 below lines before mowing object pl_orig = App.ActiveDocument.OBJECT.getGlobalPlacement() pl_part = App.ActiveDocument.PART.getGlobalPlacement() ## Now drag OBJECT into Part before running following lines App.ActiveDocument.OBJECT.Placement = pl_part.inverse().multiply(pl_orig)
Also I have made this one liner one can use when the body is in global space and you just dragged it into new parent.
(tested only few times so far)
App.ActiveDocument.BODY.Placement=App.ActiveDocument.PART.getGlobalPlacement().inverse() * App.ActiveDocument.BODY.Placement
Be careful to run this line only once, and indeed in the only simple case that you mentionkoirat wrote: ↑Wed Oct 13, 2021 11:15 pm Also I have made this one liner one can use when the body is in global space and you just dragged it into new parent.
(tested only few times so far)Code: Select all
I was looking for this featura and ended creating my own macro use it like in blender. Last node will the the future parent
__Title__ = "Reparent"
__Author__ = "PedroBarrio"
__Version__ = "00.01"
__Date__ = "2023.6.7"
debug = False
'''Usage:
This macro Changes parent maintaning Global coordinates.
Last Object Selected should be the parent.
If the shape is a BaseFeature inside a body, the base feature's placement in the body is adjusted.
def printObjectInfo(obj):
print(f'ObjectName is {obj.Name}')
print(f'ObjectLabel is {obj.Label}')
print(f'Placement is {obj.Placement}')
print(f'GlobalPlacement is {obj.getGlobalPlacement()}')
for par in obj.InList:
print(f'Parent is {par.Name} with Label {par.Label}')
for prop in par.PropertiesList:
print(f' {prop} = {getattr(par,prop)}')
if getattr(par,prop) == obj:
print( "Changed property '"+prop+"' of object "+par.Label+" from "+obj.Label+" to ")
## Objetos seleccionados
selt = Gui.Selection.getSelection()
## Comprobaciones
if len(selt) < 2:
print('Select More than 1 objects, the last one should be the new parent')
shift = App.Vector(0, 0, 0) # bail and do nothing
else:
## Target es el último elemento
tar = selt[-1]
print('\n Target Object')
printObjectInfo(tar)
## Comprobamos que el destino sea de tipo part
if (tar.isDerivedFrom("App::Part") == False):
print('Target object is not of type Part')
else:
App.ActiveDocument.openTransaction('Undo Reparent Mantain Coordinates ')
for obj in selt:
if (obj != tar):
print('\n Moving Object')
## Cambiar localizacion
obj.Placement= tar.getGlobalPlacement().inverse().multiply( obj.getGlobalPlacement() )
## Cambiar de padre
## Quitar del padre original
if (par.isDerivedFrom("App::Part")):
par.removeObject(obj)
## Poner en el padre nuevo
tar.addObject(obj)
App.ActiveDocument.commitTransaction()
