IFC export workaround and question
thomas-neemann
Post by thomas-neemann »
paullee asked me to create this theme.
a problem is described here with a workaround. the question is whether it goes as expected?
https://forum.freecadweb.org/viewtopic. ... 30#p530663
thomas-neemann
Re: IFC export workaround and question
here is a workaround with which you can even continue working in the ifc file, which is often desired, but does not correspond to the bim idea. where it can make sense is in proposals for breakthroughs
https://www.youtube.com/watch?v=7d0dE9vcEVM
phpBB [video]
Version: 0.20.28929 (Git) AppImage
Branch: (HEAD detached at 6f24fd3)
Hash: 6f24fd3053a89a5fb12ab765f9df93ec04deeac1
paullee
Post by paullee »
Thanks for testing.
You may try in Preference, to Disable IfcRectangleProfileDef, or use Brep in export.
thomas-neemann
paullee wrote: Mon May 30, 2022 12:36 am Thanks for testing.
You may try in Preference, to Disable IfcRectangleProfileDef, or use Bref in export.
unfortunately neither works for me
bernd
Post by bernd »
No problems here, at least not the ones which breaks the export ...
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * 3dfindit
  * A2plus
  * animation
  * BCFPlugin 1.0.0
  * BIM
  * BIMStatik
  * bimtester
  * bimtesterdata
  * BOLTSFC
  * Cubus
  * ETHcasDIGITAL_1819
  * FEMExamples
  * FEMToolBox
  * flamingo
  * FreeCAD-NativeIFC 2022.10.20
  * geoosm
  * hfcMystran
  * IFCToolBox
  * lattice2 1.0.0
  * Macros
  * MinWB
  * MyWB
  * MyWorkBench
  * Octahedron
  * PartFromWeb
  * PropertyToolBox
  * Raumbuch
  * README.md
  * Rebar
  * rebar2
  * Reinforcement
  * smartbim
  * SwissNPK
  * timber
  * trails
paullee
Post by paullee »
Thanks for testing Bernd, seems something on upper roof floor are missing :)
thomas-neemann
bernd wrote: Wed Feb 22, 2023 2:44 pm No problems here, ....
Thank you for your work, but I can't do it with your settings either.
Version: 0.21.0.31917 (Git) AppImage
  * 3D_Printing_Tools
  * Curves 0.6.6
bernd
Post by bernd »
We will find it if you would help. If you use my prefs debug is on. Would you post the output of report console?
We need to find the object which does make the problem. A FreeCAD file with just this object should be our target.
thomas-neemann
bernd wrote: Wed Feb 22, 2023 7:30 pm We will find it if you would help. If you use my prefs debug is on. Would you post the output of report console?
here it is. I haven't installed the bim workbench, is it necessary?
20:45:32  Traceback (most recent call last):
  File "<string>", line 8, in <module>
  File "/tmp/.mount_31917-DA7Spy/usr/Mod/Arch/exportIFC.py", line 546, in export
    product = createProduct(
  File "/tmp/.mount_31917-DA7Spy/usr/Mod/Arch/exportIFC.py", line 2399, in createProduct
    product = getattr(ifcfile,"create"+ifctype)(**kwargs)
  File "/tmp/.mount_31917-DA7Spy/usr/lib/python3.10/site-packages/ifcopenshell/file.py", line 276, in create_entity
    e[idx] = arg
  File "/tmp/.mount_31917-DA7Spy/usr/lib/python3.10/site-packages/ifcopenshell/entity_instance.py", line 190, in __setitem__
    method = self.method_list[idx]
<class 'IndexError'>: list index out of range
bernd
Post by bernd »
How about the lines before. Do you see on which object it breaks? Are you able to extract only this object into one FreeCAD document export this object only and get the same errormessage.
