Overlapping Icons
- moltenaluminium
Overlapping Icons
The last few times I've compiled FreeCAD, I'm seeing the icons and window edges cut off and overlap. Has anyone else seen this issue. It only seems to ba an issue with FreeCAD. Here is a screenshot of what I'm seeing:
I'm running:
64 Bit Arch Linux
Compiling master branch:
cmake -Wno-dev -G Ninja -B build_dir -S . \
-D BUILD_ENABLE_CXX_STD=C++14 \
-D BUILD_QT5=ON \
-D BUILD_FEM=ON \
-D BUILD_MESH=ON \
-D BUILD_MESH_PART=ON \
-D BUILD_SHIP=ON \
-D BUILD_ASSEMBLY=OFF \
-D BUILD_COMPLETE=ON \
-D BUILD_PLOT=ON \
-D CMAKE_BUILD_TYPE=None \
-D CMAKE_C_FLAGS="${CFLAGS} -fPIC -w" \
-D CMAKE_CXX_FLAGS="${CXXFLAGS} -fPIC -w" \
-D FREECAD_USE_EXTERNAL_PIVY=ON \
-D FREECAD_USE_OCC_VARIANT="Official Version" \
-D FREECAD_USE_QT_FILEDIALOG=ON \
-D PYTHON_EXECUTABLE=/usr/bin/python \
-D INSTALL_TO_SITEPACKAGES=ON \
-D CMAKE_INSTALL_PREFIX="${_destdir}/lib/freecad" \
-D CMAKE_INSTALL_BINDIR=bin \
-D CMAKE_INSTALL_LIBDIR='../../lib' \
-D CMAKE_INSTALL_DATADIR='../../share/freecad' \
-D CMAKE_INSTALL_DATAROOTDIR='../../share' \
-D CMAKE_INSTALL_DOCDIR='../../share/doc/freecad'
cmake --build build_dir
I'm running:
64 Bit Arch Linux
-D BUILD_QT5=ON \
-D BUILD_FEM=ON \
-D BUILD_MESH=ON \
-D BUILD_SHIP=ON \
-D BUILD_PLOT=ON \
Re: Overlapping Icons
Moved to Install/Compile subforum
is this a HiDPI issue?
- moltenaluminium
How would I check that?
I'm using the Mate Desktop on Arch linux. My screen rez is 1920(3840) x 1080 across 2 monitors. I'm not using a retna display or anything fancy.
If I understand you correctly, this happens only with the self compiled version, and neither with freecad-daily nor with the AppImage?
- moltenaluminium
That is correct.
Did you post your About info?
+1
In particular, is this the HEAD from git, or a 0.19 release? And which version of Qt are you compiled against?
- moltenaluminium
OS: Arch Linux (MATE/mate)
Version: 0.20.25552 (Git)
Hash: d0de6284f914dc02b4d494b96c4ee0c5762c4c24
Python version: 3.9.6
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
the about screen looks like this:
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Very interesting - not just overlapping icons, but basically the whole interface, every individual element, is being clipped somehow. We should see if any other Arch/MATE users can reproduce this issue.
ETA - As a side note, your flags are a bit out of date, you should be using -D BUILD_ENABLE_CXX_STD=C++17, and the QT5 define is no longer used, we don't support Qt4 in 0.20 dev.
