#4828 PartDesign: inverse for pocket
rynn
Post by rynn »
This adds an “inverse” option for PartDesign pocket feature.
Essentially this cuts away anything that is +not+ covered by the
sketch. (boolean common instead of cut.)
see englisch or german forum.
https://github.com/FreeCAD/FreeCAD/pull/4828
GeneFC
Re: #4828 PartDesign: inverse for pocket
Post by GeneFC »
I would use this a lot. Thanks!
However, the name seems a bit confusing, at least in English. To me an "inverse pocket" would be the same as a "pad".
I have not thought enough about a better name, but something like "outer pocket" or "external pocket" would sound better to me.
Gene
Isn't this a boolean "Common"?
rynn
Post by rynn »
chrisb wrote: Mon Aug 16, 2021 9:47 pm Isn't this a boolean "Common"?
Yes.
GeneFC wrote: Mon Aug 16, 2021 9:25 pm However, the name seems a bit confusing, at least in English.
In the UI it’s called “remove outside of profile” now.¹
The parameter is called “Outside”.
__________
¹ The new naming came with Adrians patch
openBrain
Post by openBrain »
rynn wrote: Mon Aug 16, 2021 5:53 pm This adds an “inverse” option for PartDesign pocket feature.
The PR is pretty old. Is there a particular reason why you opened this thread ?
No please. I'm in favor that boolean vocabulary is kept away from PartDesign. :)
rynn
Post by rynn »
openBrain wrote: Tue Aug 17, 2021 7:00 am The PR is pretty old. Is there a particular reason why you opened this thread ?
Yes. Because it is pretty old ;)
openBrain
Post by openBrain »
rynn wrote: Tue Aug 17, 2021 9:17 am Yes. Because it is pretty old ;)
Actually it's not regarding FC merging pace. I have one that is 1.5-year old while only a few lines. :) Being patient is the only way to go. :lol:
openBrain wrote: Tue Aug 17, 2021 7:00 am No please. I'm in favor that boolean vocabulary is kept away from PartDesign. :)
Agreed, as we don't call a Pad a Union :) .
ThomasT
Post by ThomasT »
Would "Crop" be a good name for this function? It is short and is known from 2D programs.
rynn
Post by rynn »
And… another month gone – frustrating.
