#4828 PartDesign: inverse for pocket
Re: #4828 PartDesign: inverse for pocket
it's definitively more than one single extrusion and cut, and it's also problematic (not to say impossible) to obtain the addsubshape from a common operation. If we don't need to go with the more expensive operation we should not use it. In simple projects you will not feel the difference, but on complex model (specially on low end computers) it can be noticeable.
wsteffe
Post by wsteffe »
user1234 wrote: Thu Mar 23, 2023 7:56 pm So it is only a split, a common and a add. I find that is not that much, also in relative to multiple patterns.
That has to be compared with a single cut (plus adding a wire which is a very fast operation).
And I would also add a refine to get rid of the additional edges in the split plane (not created by the single cut).
A refine can break a model. It should never be applied automatically unless configured as such in the preferences.
wsteffe
Post by wsteffe »
chrisb wrote: Fri Mar 24, 2023 8:41 am A refine can break a model. It should never be applied automatically unless configured as such in the preferences.
In fact. And this is another argument against "split+common+union" which would require also a refine to get the same result of "pocket with sketch+wire"
