Sketcher Rectangular Array - parametric use
in the sketcher there is a feature "Create Array" (https://wiki.freecadweb.org/Sketcher_RectangularArray)
Does anyone know if it is possible to use this in a parametric way? (creating a cable holder, want to dynamically create the right number of holes in the sketch)
Version info:
OS: Ubuntu 21.04 (ubuntu:GNOME/ubuntu-xorg)
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Python version: 3.9.5
Qt version: 5.15.2
OCC version: 7.5.2
Version info:
Version: 0.19.
Branch: unknown
Qt version: 5.15.2
OCC version: 7.5.2
Free as in freedom.
Free as in beer - but please... don't forget to occasionally pay for your drinks.
* FreeCAD * Inkscape * LibreOffice * Ubuntu * OBS Studio * Netcloud *
Re: Sketcher Rectangular Array - parametric use
No, it's just a macro to help you in your sketch.
You should use Transformation tools (eg PartDesign_LinearPattern)
It is not possible. For that you should use some patterning feature.
Thanks for the clear answer. I thought so, and hoped to be wrong
Free as in freedom.
Why ? Explain your problem (image, file). We are full of good ideas.
This is a small cable holder. I designed all (most) parameters in the sketch now.
I could redo it, but my lazy butt was hoping not to have to redo some work
This gimmick is to bind my USB cables, but if I make it thicker, it also does other cables.
Now, the teeth help keep the wire organised. I will have to revert to making these dents as separate objects.
Free as in freedom.
Not separate objects, only separate features. And then you model only half of it and make a multitransform with linear pattern + mirror.
- papyblaise
you draw a 1/2, Pad
you draw a tooth, Pad and Linear Patern 3 times
you Miror in the Part workbench (PartDesign does not work), (light green)
- clip.FCStd
- (34.34 KiB) Downloaded 22 times
- clip.PNG (18.48 KiB) Viewed 1101 times
Mirror Pad first. Then it will let you add a mirror to the multitransform.papyblaise wrote: ↑Wed Aug 11, 2021 2:37 pm you draw a 1/2, Pad
- clip (1)_markster.FCStd
- (45.48 KiB) Downloaded 23 times
