That's how I see it too, thanks
Collection of differences between original master version and realthunder
- thomas-neemann
Re: Collection of differences between original master version and realthunder
Done.
- thomas-neemann
in the master you can still not switch it off (via the tick)
Version: 0.20.28751 (Git) AppImage
Branch: (HEAD detached at 660655e)
Hash: 660655e54c97b5017ff0ac1e030059308cd4e3f5
- thomas-neemann
apparently contraints in assembly3 in master are not working properly
https://www.youtube.com/watch?v=Se-tMzkKaj4
realthunder
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
master
Version: 0.20.28765 (Git) AppImage
Branch: (HEAD detached at 795f86c)
Hash: 795f86c18c22260cfc3627bdd5b71504b9dca4ef
edit
the difference is that auto recompute is pre-set in realthunder. not in the master
realthunder
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
master
edit
Last edited by thomas-neemann on Mon May 02, 2022 12:49 pm, edited 1 time in total.
I refuse to look at Youtube without at least some indication in writing, here in the forum, as to what am I supposed to expect to see there....
- thomas-neemann
the connection is not fixed in the master, in realthunder you cannot disconnect it with transform
Are you using standard transform (https://wiki.freecadweb.org/Std_TransformManip) ??thomas-neemann wrote: ↑Mon May 02, 2022 9:59 am the connection is not fixed in the master, in realthunder you cannot disconnect it with transform
BTW there is (and I was there some time ago as well ) a lot of confusion about using standard transform after constraining assemblies.
from @realthunder:
see: https://github.com/realthunder/FreeCAD_ ... -835246489It is not possible to use the Transform command for moving assemblies, because assembly mover is aware of assembly hierarchies and will modify the the Placement property of the correct assembly/part object in the hierarchy, while the Transform command only works for the selected object.
Have you got "auto recompute" set on in both Link and Master? - doesn't look like it to me?
This video doesn't prove a lot.... and most certainly not that:
"...assembly3 in master are not working properly..."
It looks to me more like user error
- thomas-neemann
Thanks for the tip, that's the solution. the difference is that auto recompute is pre-set in realthunder. not in the master.
- thomas-neemann
this hotkey has probably changed.
source: https://wiki.freecadweb.org/Sandbox:Key ... _Workbench
in realthunder it is as described in the documentation. in the master it is still the old method
Version: 0.20.28774 (Git) AppImage
Branch: (HEAD detached at 716213b)
Hash: 716213beacd25a907f2c164ad8ef8309b8a284b0
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
- thomas-neemann
master has .57 point cloud import. realthunder doesn't have it
edit .e57
edit .e57
Last edited by thomas-neemann on Fri May 06, 2022 12:53 pm, edited 1 time in total.
