Vila Matilde House, working with linked files
- duncan.lithgow
Re: Vila Matilde House, working with linked files
Fantastic work - now we have to make all of this into good feature requests.
paullee, ragohix769 and duncan.lithgow,
I appreciate the feedback!
About the file sizes:
The single initial file (without the terrain and surroundings) is 110 MB (bearing in mind that it hasn't been updated for a while). Adding the land and surroundings, it would go to about 130 MB.
The files of the disciplines totalize almost 150 MB (148.7 MB). Each BIM file (Base and Drawings) is almost 60 MB, so multiplying by the number of sheets (7) plus the BIM_Base we would have more 480 MB, totaling in this case, around 630 MB.
Therefore, the increase in file size is significant. But, comparing with the processing time and RAM memory expenditure dedicated to the FC, the figure is different (i5 CPU with 8 GB of RAM):
Single file:
RAM - it starts at 2.0 GB and grows with each modification easily reaching 3.0 GB or more.
Re computation time (with the seven drawing sheets) is over 17 minutes! An average of 2.5 minutes per sheet.
Linked files:
RAM - it starts at 1.4 GB and doesn't grow as much as before.
Re computation time is about 2 minutes per sheet (only for BIM_Drawings file, the disciplines files are not compromised!).
But the most important thing is that with a single file the work becomes unfeasible, there is no way to wait so long for each modification in the drawings or even in the 3D model, because of this I looked for the solution to work with the linked system. In addition, in this system, linked files can still be added, without major loss of performance, and it allows for the necessary teamwork.
Single file:
Linked files:
- HakanSeven12
Another nice work
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
beautiful work!!
HakanSeven12 and Renato Cruz,
Thanks!
paullee,
First, I imagine you are testing the templates and I would like to thank you for that, two heads are better than one! Second, I don't believe in dogmas and everything here must be checked and improved.
Regarding the exporting the FC format to IFC, look that in the model I presented (figure 09, from "The BIM Framework and FreeCad (FC)" post) it "follows its natural path", that is, it would be exported from the original files and not from your links. So I haven't tested from this one, ok? But I think this option could be open, no doubt.
Thanks!
paullee,
Nice project! To bad the calculation takes so much time. What does it take to improve this? Is this something in the core of Freecad that needs to be improved? Is anyone already working on this? Do you feel that this holds the use of Freecad for architecture drawing back?
You can adjust the cpu-threads when using FEM/cfdof/FrontISTR workbenches.
This is pure numerical stuff for speeding up the solvers.
There is a workbench called dualsphysics. This wb can use the gpu (nvidia only)
to simulate particle flow. Which speeds up the calculation.
Never tried to run FC on multi cpu/gpu.
Sir, amazing work!
Thanks!
I made some suggestions. I believe there are a lot of people working on this, but I can't answer in the programming area, and it would be nice if someone from that area let us know.
From my point of view, I believe that it is possible to accomplish a lot, so much so that I have been working with FC. But there are undoubtedly improvements to be made.
Thank you, it is good to know it.thschrader wrote: ↑Mon Jul 12, 2021 7:45 pm
Thanks for your compliment!
I almost forgot to thank bitacovir for posting and updating on the OSArch wiki!
¡Muchas gracias!
¡Muchas gracias!
