Page 1 of 1
Path simulator bug?
Posted: Sat Jul 10, 2021 9:15 pm
by Giulio Buccini
I was just playing with the "Linear2D" array command to duplicate some circular pockets on a plane.
I noticed that if I try to simulate the path then only the milling ops on the first pocket are executed, the other pockets are ignored.
I missing something?
(I attach my file.)
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.20.25065 (Git) AppImage
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Re: Path simulator bug?
Posted: Sat Jul 10, 2021 10:20 pm
by Russ4262
Giulio Buccini wrote: ↑Sat Jul 10, 2021 9:15 pm
... I noticed that if I try to simulate the path then only the milling ops on the first pocket are executed, the other pockets are ignored.
Afternoon from the sunny state of Oklahoma in the United States of America. I am taking a look at your file and the issue you are reporting. First test confirms your reported issue. I am now looking into the code for the cause.
Russell
Posted: Sat Jul 10, 2021 10:41 pm
by Russ4262
Me again.
The problem appears to be that the `Array` object lacks the `Active` property that other operations possess. I will see if I can identify a proper solution for this issue. Feel free to create a
bug tracker ticket for this issue.
I currently have an open PR that refactors the `PathArray` module. If I identify a solution to this issue, I may append it to that PR.
Thanks for reporting the matter. Have a great afternoon.
Russell
Posted: Sun Jul 11, 2021 1:44 am
by Giulio Buccini
Hi Russel, 3:30 AM here in Germany.
Anyway the generated g-code seems ok to me. So it seems a problem of the simulator only. Can you confirm?
P.S.
Following the link you posted I read: "IMPORTANT: POST ONLY 0.19 BUG REPORTS"
I'm using version 0.20 ...
Posted: Sun Jul 11, 2021 3:05 am
by Russ4262
Giulio Buccini wrote: ↑Sun Jul 11, 2021 1:44 am
... So it seems a problem of the simulator only. Can you confirm? ...
Good early German morning!
I can confirm the issue is isolated to the simulator.
I have added a simple fix, adding the `Active` property to the Array object, to the existing PR #4818,
[Path] Refactor path array algorithm into independent PathArray class. I tested the fix and it does allow the simulator to include the Array object in the simulation. I also added the Path Array operation to the recognized list for the `Active` toggle in the Path WB toolbar since it will now have the dependent `Active` property for the toggle process.
P.S.
The bug does exist in 0.19 also. You are simply a very astute individual that uses the latest and greatest version.
Have a great day. Thanks for making FreeCAD better.
Russell
Posted: Sun Jul 11, 2021 9:16 am
by Giulio Buccini
