Install the Snip addon macro and create an icon for it in the global toolbar.
call for screenshots - By Yorik
Re: call for screenshots - By Yorik
The Snip macro can scale. Almost all of my screenshots are made with it and scaled down by 50%. It results in slight loss of resolution, but I think they are still ok.
- jimmihenry
Thank you for your effort, i did try this approach but it did not work out for me. The sketch on sheet broke constantly, it was easier for me going for the shown approach. I did not mirror the half of the clip, i linked it instead and rotated it 180°this time. Finally i would make a boolean union, after unfolding if necessary.FBXL5 wrote: ↑Tue Oct 25, 2022 6:18 amThere's another approach on the paper clip using SheetMetal: SheetMetal_Examples#Paper_clip
I'm sorry, but have no renderer installed and I have no clue how to scale down linked images to not waste space.
The main criteria for me was to create the clip in first place. Sure there are many ways to do that! However try to come up with this shape of the cut out, this is a design result. Therefore you have CAD
- clip skech.png (13.47 KiB) Viewed 5936 times
- binder clip unfold.PNG (135.65 KiB) Viewed 5936 times
Exploring nested array structures with FreeCAD Nodes (https://github.com/j8sr0230/fc_nodes).
Codelink on GitHub: https://github.com/j8sr0230/codelink
Codelink on PiPy: https://pypi.org/project/codelink/
FreeCAD Nodes Workbench on GitHub: https://github.com/j8sr0230/Nodes
Mine was to have a use case for the Sketch On Sheet metal funktion (and then to unfold it in one piece) to fill some wiki void.jimmihenry wrote: ↑Tue Oct 25, 2022 5:52 pm The main criteria for me was to create the clip in first place.
I wish I had time to try this out...
- ragohix769
j8sr0230 wrote: ↑Wed Oct 26, 2022 1:00 pm Exploring nested array structures with FreeCAD Nodes (https://github.com/j8sr0230/fc_nodes).
- jimmihenry
It is not like you would have to spend a week on it!FBXL5 wrote: ↑Wed Oct 26, 2022 1:08 pmMine was to have a use case for the Sketch On Sheet metal funktion (and then to unfold it in one piece) to fill some wiki void.jimmihenry wrote: ↑Tue Oct 25, 2022 5:52 pm The main criteria for me was to create the clip in first place.
- Niky just do it.jpg (42.78 KiB) Viewed 5755 times
for Windows users I have put together a dependency-free version of FreeCAD Nodes today (other operating systems will follow). If you want to test FreeCAD Nodes as a workbench, just download the package from the link https://github.com/j8sr0230/fc_nodes/tr ... n_dep_free (Code -> Download ZIP), unzip the archive and copy the SUBFOLDER to your Workbench directory (e.g. C:\Users\admin\AppData\Roaming\FreeCAD\Mod). After starting FreeCAD you should find the new Workbench. It contains a toolbar icon that can be used to start the node editor. I have tested the package with FreeCAD 0.20 stable, FreeCAD 0.21 daily and the latest FreeCAD Link Branch without any problems. Let me know if it works for you ...
