... yep ,more LEDs. I went to look some thing up on the internet and came back with a data sheet of a Piranha,
Super Flux LED. (That's how i came up with the Kingbrights LED bars
). I am not sure but i would like to believe
there are a Piranha and a Super Flux LED, two different LEDs. See first and second image.
Worth mention the appearance of the LED is 100% FreeCAD. FreeCAD can show 3D objects in a way KiCAD does,
it almost looks the same. Check it out and import VRLM files with all the lightning options to FreeCAD.
You can also export VRML using KiCAD and compare the exact same files. Or export VRML from FreeCAD direct,
or via the KiCADStepUpMod. Last option is how i make KiCAD files for electronic projects and librarys.
If you would like to replicate the visualisation of the seen parts, here is a tiny tutorial.
1. Make your own LEDs. (Or download some here:
https://grabcad.com/jimmi.henry-1/models)
2. Steal the texture from the "KiCADstepMod" tool if you are interested in the texture file only go to:
https://github.com/easyw/kicadStepUpMod ... s/textures and download the
3. Now it is time to prepare your parts visual presentation like line width, point colour, transparency etc...
4. After you are happy with the appearance of your part go to FreeCAD menu -> View -> Texture mapping
than choose the downloaded
infinite_reflection_blur.png via the drop down menu. Tick the Environment box.
5. Choose your option to save a picture or run a script like Marios52
Screen_Wiki macro... Done!
Images below show a Piranha and a Super Flux- RGB LED. In order top to bottom.
