[Fixed]New light icons for the Navigator Indicator for Dark themes
I suggest using these modified original icons that i inversed the color. Install them in FreeCAD/src/Gui/Stylesheets/images_dark-light/ so that Stylesheet creators can access them. I've attached the icons if someone wants to improve or review them
Proposed Current
Proposed Current
- NavigationIndicatorIcons.7z
- (1.68 KiB) Downloaded 91 times
Re: New light icons for the Navigator Indicator for Dark themes
The usual way of handeling this is to store both icons in the same directory and selecting which version based on type of theme (light vs dark) when loading the icon.
Do you know your way around freecad’s source code or would you like me to look into this for you? (I can do it this weekend)
I only know enough to design so if you could look into it for me that would be great. Thanks.hyarion wrote: ↑Thu Mar 25, 2021 7:47 am The usual way of handeling this is to store both icons in the same directory and selecting which version based on type of theme (light vs dark) when loading the icon.
Hi hyarion, nice of you to take a look if this can be integrated with a selection between light/dark theme. Perhaps you could collaborate with https://forum.freecadweb.org/viewtopic. ... 20#p489527 ? He is already setting up a gui for quickly change the theme based on presets.
Perhaps you can take a look at how Affinity Photo does this. They give a option for a Dark and Light theme. You can than adjust the UI Gamme to finetune the color. Now in Freecad there are Dark-, Darker- and Light-style sheets. With blue, green, and orange accent colors. Or without accent color like ProDark. Perhaps freecad could have a switch between Dark, Darker and light and than a switch to select accent color?
- Affinity Photo Theme selection.JPG (28.75 KiB) Viewed 2881 times
turn211 wrote: ↑Thu Mar 25, 2021 4:43 pmI only know enough to design so if you could look into it for me that would be great. Thanks.hyarion wrote: ↑Thu Mar 25, 2021 7:47 am The usual way of handeling this is to store both icons in the same directory and selecting which version based on type of theme (light vs dark) when loading the icon.
I've looked into this and I must admit that I was wrong. It is much better to let the stylesheet creator specify this instead as you suggested.
This way it is possible to use a both light and dark versions in the same theme, if needed (for instance you might want to use different colors if the button is highlighted or not).
I've created a pull request here for adding the new files and changed the old once to match the new naming (_light/_dark):
https://github.com/FreeCAD/FreeCAD/pull/4694
I'm not sure what you're asking. Maybe I missed something but wasn't that thread about an expanding toolbar? I didn't see anything about adjusting colors.Meetlat wrote: ↑Fri Mar 26, 2021 6:53 am Hi hyarion, nice of you to take a look if this can be integrated with a selection between light/dark theme. Perhaps you could collaborate with https://forum.freecadweb.org/viewtopic. ... 20#p489527 ? He is already setting up a gui for quickly change the theme based on presets.
- adrianinsaval
Could you then add a parameter to override the used icon? I use a system set dark theme (I'm using KDE) so I don't think the icons will be changing for me like this.hyarion wrote: ↑Tue Mar 30, 2021 9:20 pm I've looked into this and I must admit that I was wrong. It is much better to let the stylesheet creator specify this instead as you suggested.
If you are using a system wide theme you are not using a stylesheet. You do not have to worry about any of this.adrianinsaval wrote: ↑Tue Mar 30, 2021 10:17 pm Could you then add a parameter to override the used icon? I use a system set dark theme (I'm using KDE) so I don't think the icons will be changing for me like this.
Thanks! Very helpful. Great ideas. This now repairs all known Dark theme problems. Now I'll start designing a ProLight Theme.hyarion wrote: ↑Tue Mar 30, 2021 9:20 pmturn211 wrote: ↑Thu Mar 25, 2021 4:43 pmI only know enough to design so if you could look into it for me that would be great. Thanks.hyarion wrote: ↑Thu Mar 25, 2021 7:47 am The usual way of handeling this is to store both icons in the same directory and selecting which version based on type of theme (light vs dark) when loading the icon.
