@mario52 is there a macro that exists for this?mario52 wrote: pinged by pinger macro
New ProDark Theme with 4k small text Mod
Re: New ProDark Theme with 4k small text Mod
Sounds good by me. I haven't used Macros myself. Still learning GitHub. New PR 4586Kunda1 wrote: ↑Fri Mar 05, 2021 7:22 pmMaybe we should make a macro that auto-changes all these in the user.cfg file?turn211 wrote: ↑Fri Mar 05, 2021 6:35 pm Glad you got it sorted out. Yes all those colour choices can be changed in Preferences. If your happy great, but you could use the ProDark Theme colours listed in https://forum.freecadweb.org/viewtopic. ... 80#p482055
Just a heads up that QPushButton min-width: 70px; doesn't play perfectly well with some of the third-party add-ons (I.e. Defeaturing Tools). This could potentially interfere with anything that is using PushButtons. Maybe it would be a good idea not to force the width?
Thanks for communicating this. Both of you are doing important work and it makes me happy to see that there is an open channel of communication between freecad master branch and linkstage3.
Thanks for the heads up. Never used this add-on. My bad. Will still use QPushButton min-width: 70px;as it's a design element of the ProDark theme but will isolate only the widgets that need this style instead of globally. Taking a guess this Add-on seems to have a maximum frame or grid size set as dialog can't expand. Other Add-ons don't have this limitation. I see though it is like a calculator so must be intentional. With these constraints i have styled accordingly but will have to clean up code. Will release soon.Petrikas wrote: ↑Sat Mar 13, 2021 10:25 pm Hello,
- Defeaturing_Tools_Add_on.png (181.73 KiB) Viewed 3546 times
@easyw is the author of defeaturing wb. Just giving a heads-upeasyw wrote: pinged by pinger macro
please have a look also to:turn211 wrote: ↑Sun Mar 14, 2021 6:52 am Thanks for the heads up. Never used this add-on. My bad. Will still use QPushButton min-width: 70px;as it's a design element of the ProDark theme but will isolate only the widgets that need this style instead of globally. Taking a guess this Add-on seems to have a maximum frame or grid size set as dialog can't expand. Other Add-ons don't have this limitation. I see though it is like a calculator so must be intentional. With these constraints i have styled accordingly but will have to clean up code. Will release soon.
1) Manipulator WB
2) kicadStepUp WB
they are based also on the same structure of Defeaturing WB
All Add-ons themed with workarounds. Looks good. Since none of the QPushButtons had text but used icons and these Add-ons used a grid format QToolbarButtons would been a better/easier solution IMHO. Anyway all fixed now. Cheers!
Lots of handsome improvements including Add-ons theming, Button contrast usability theming and more. I'll let everone try it out before submitting a PR. Get it at https://github.com/turn211/ProDark-FreeCAD-theme More pics to come.
The Image Scaling window (Image Workbench) does not have the text in ProDark Theme.
- Change to ProDark Theme
- Open Image workbench
- Click on Image Scaling icon on the toolbar. The window that shows up does not have text...
Image Scaling window with ProDark theme: .
Image Scaling window with no style sheet: OS: Windows 10 (10.0)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
