Ball-bearing yoyo designs
Mark1D
Post by Mark1D »
Hello everyone,
I design high-end yoyos, and run a yoyo company as a hobby. I used to use Fusion360 but switched to FreeCAD recently after my free license for Fusion expired.
Most yoyos are pretty simple as far as CAD goes. There's a sketch, and you revolve it to get the body. Some of the dimensions are important (where the bearing sits) and some are very aesthetic in nature, or subject to how you'd like the yoyo to play (powerfully, light, etc).
However, this design is a larger challenge because the body of the yoyo will be constructed from polycarbonate, with steel weight rings on the outside. The hub that holds it together will be aluminum, with a tiny spacer against the inner race of the bearing so that it will spin freely. Furthermore, there will be profile holes cut-out in a cool hexagon pattern. This reduces the mass of the yoyo somewhat, but it's mostly for looks, because they will also cause air turbulence that may negate any performance gains of a design like this.
It's a bit of a pain to iterate on because the hole features are very time consuming to calculate if anything changes. I usually delete the polar array, make changes, then re-add it.
I made an earlier version of this design in Fusion and decided recently to re-make it in FC 0.19.
Here's how it looks in FC:
And in 3D:
A design like this will weigh about 63 grams, and it's 57mm in diameter. The steel rings are the bulk of the mass.
Here it is rendered out with Blender:
I hope to have prototypes of this ordered later this year after I'm fully happy with the design.
Mark1D
Re: Ball-bearing yoyo designs
Post by Mark1D »
I created a macro to help calculate the density/mass moment of inertia for complicated parts like this:
https://github.com/mdiehr/FCMacros/blob ... fo.FCMacro
I used some portions of the great FCInfo macro to create this.
How it works, is that it looks through all of the objects in the document:
2021-02-14 14_01_27-FreeCAD Link Branch.png (11.75 KiB) Viewed 5924 times
Then, for each part, it pulls the density out of the part label (it has to be exactly at the end of the label), displays the mass of each part, and the overall mass and moment of inertia for the assembled yoyo:
2021-02-14 14_01_58-FreeCAD Link Branch.png (271.15 KiB) Viewed 5924 times
Storing the density in the label is not the best way to do this, but it was easy for me to figure out how to store information there, it's highly visible, and it allows an easy way to include/omit parts that shouldn't be part of the calculations.
doul
Post by doul »
Hello, great work. the multi material design is awesome.
FreeCAD is cool 8-)
Mark1D
Post by Mark1D »
Here's a render of a new version in POM with chamfers and an internal radius on the cutouts. My machinist told me that polycarbonate probably wouldn't hold up to CNC milling.
montagdude
Post by montagdude »
Cool! Do you have a website for your yo-yo company, if it's okay to post that here? I am into yo-yos too, and I'd like to see what you have.
galou_breizh
Post by galou_breizh »
You could use a dynamic property to store the density (https://wiki.freecadweb.org/Release_not ... namespaces).
I guess you can also directly associate a material to a body but I never used this.
Gaël
Mark1D
Post by Mark1D »
montagdude wrote: Wed Feb 24, 2021 3:43 pm Cool! Do you have a website for your yo-yo company, if it's okay to post that here? I am into yo-yos too, and I'd like to see what you have.
Here it is: https://mk1yoyos.com/
Mark1D
Post by Mark1D »
galou_breizh wrote: Wed Feb 24, 2021 6:38 pm You could use a dynamic property to store the density (https://wiki.freecadweb.org/Release_not ... namespaces).
Gaël
I'll try this out, thank you!
oldboffin
Post by oldboffin »
I think your rendered view is great, what did you use to do it and can you tell us what your computer is. BTW I think you should have no trouble machining polycarbonate.
Great work, thanks for sharing.
Mark1D
Post by Mark1D »
oldboffin wrote: Fri Feb 26, 2021 9:59 pm I think your rendered view is great, what did you use to do it and can you tell us what your computer is. BTW I think you should have no trouble machining polycarbonate.
Thank you!
The renders were created in Blender. I am using a 7 year old gaming PC that was around midrange when I built it. Renders like this take about 10-12 minutes, mostly because the subsurface scattering is expensive.
The FreeCad to blender workflow is actually pretty smooth most of the time. For purely revolved parts I am exporting a flattened SVG (with a crosshairs on the center point for reference finding in blender) and then using Blender's revolve-like tool (the screw modifier) to create the 3d bodies. This allows me to make a parametric mesh that doesn't use up very much disk space, and I can adjust the number of steps in the revolve for renders only, if needed.
It's a bit tougher for this cutout yoyo, I ended up using the collada file export and dropping it in directly.
