Export suddenly doesn't work for certain models
andrigtmiller
Post by andrigtmiller »
I have never had a problem with exporting to STEP or STL before, but yesterday I noticed that my STEP export on one model was failing silently. It wouldn't give any error message, but no file would be written.
Then, as a test, I decided to export to STL, which I do all the time, and that fails with an error message saying:
Export Failed
Can't determine mesh formal from file name: <insert file name here>
Whenever the above happens STEP files can't be exported either, but they fail silently. This makes it hard to 3D print the things I'm working on. This happens on the latest release version of 0.18, and the latest 0.19 development. I'm using the development branch, because the latest release version is broken on the latest Fedora Linux.
Here is what is in the report view:
11:50:58 Loading Mesh module... done
11:50:58 Traceback (most recent call last):
File "<string>", line 4, in <module>
<class 'Base.FreeCADError'>: Can't determine mesh format from file name: '/home/andrigtmiller/Documents/Andrig's Aircooled Technology/CAD/BayWindowBusGaugePanelProfileTest'
Version information:
OS: Fedora 33 (Workstation Edition) (GNOME/gnome)
Version: 0.19.23578 (Git) AppImage
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
I have attached a model that I need to 3D print to test out the shape of a more complex model. It's super simple. Can't understand why it's failing.
BayWindowBusGaugePanelProfileTest.FCStd
(11.29 KiB) Downloaded 31 times
Re: Export suddenly doesn't work for certain models
Can you reproduce with a previous revision of 0.19?
andrigtmiller
Yes, it happens on the previous version of 0.19 as well. It does not appear to be specific to any particular version.
I was able to reproduce on 0.18 as well, even though it's broken on Fedora 33. The menus don't render correctly, but I was able to use the short cut keys to export, and I get the same issue.
So, on three different versions it happens.
kisolre
Post by kisolre »
What happens if you add the extension to the file name manually? So instead of entering "Test" as export file name you enter "Test.stl"?
thomas-neemann
Post by thomas-neemann »
andrigtmiller wrote: Mon Jan 04, 2021 6:57 pm
I would test it out of the box without macros, it works for me
andrigtmiller
kisolre wrote: Mon Jan 04, 2021 7:33 pm What happens if you add the extension to the file name manually? So instead of entering "Test" as export file name you enter "Test.stl"?
Well, I just tried it, with manually putting the .stl file extension on, and it worked. I opened the STL file to see if it seemed valid and it does.
Weird. Why would it do this on some models and not others?
andrigtmiller
thomas-neemann wrote: Mon Jan 04, 2021 9:02 pm
I don't have an macros, I just use the AppImage as is, and I have only changed a few defaults here and there.
kisolre
Post by kisolre »
andrigtmiller wrote: Mon Jan 04, 2021 9:14 pm Why would it do this on some models and not others?
I remember that there should be option to use native file dialog or not and one added the extensions and the other did not... or something like that. Why it will be file dependent I have no idea.
andrigtmiller
Could be, but at least I know how to work around the issue now.
Thanks to everyone for the help. This saved my work day!
Very much appreciated!
Using 0.18 and 0.19 in parallel can in some rare cases mess up your config. You can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
