Problem opening DXF file from EAGLE
Dear FreeCAD users,
I export dxf files from EAGLE via the CAM processor. I open the dxf in QCAD and export it to dxf R13, because this is the only format, which works for me with FreeCAD. Then I extrude the file in FreeCAD and print it to a PCB using my MSLA printer.
This workflow worked for me so far... But now I created a new layout and FreeCAD just does nothing, when i try to open the dxf R13. It doesn`t hang, or throws an error message. With an older layout everything just works fine. Has somebody an idea why this file doesn`t work? I`ll attach the dxf R13.
I use the version 0.18 Rev. 4.
Thanks in advance.
PS: Sorry for my bad english.
Thanks in advance.
- Layout_R13.zip
- Had to zip it, because of size.
- (88.28 KiB) Downloaded 52 times
Re: Problem opening DXF file from EAGLE
Tested with
OS: Ubuntu 18.04.5 LTS
Version: 0.18.16158 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-18
Hash: 783e1346c7a078f5265c3f0c6a927d09a8c1fe70
Python version: 3.6.9
Qt version: 5.9.5
and
OS: Ubuntu 18.04.5 LTS (XFCE/xubuntu)
Version: 0.19.23252 (Git)
Build type: Debug
Hash: 983e513704a659c1008fbaf95da6a34975cc37ac
Qt version: 5.9.5
and for both of them it works well.
When you open the file then a dialog comes up where you can switch between 3D (importIL) and 2D (importDXF). I used the latter and after a couple of seconds the file is opened.
Build type: Unknown
Qt version: 5.9.5
and
Build type: Debug
Qt version: 5.9.5
- Layout.FCStd
- (443.01 KiB) Downloaded 44 times
Thank you very mutch for the fast reply and the CAD file.
I`m using Windows 10 so maybe there is the problem.
In my case no dialog opens. May I ask you to post a screenshot of this dialog? Or do you mean the import settings for dxf files?
Also there are over 6 thousand bug fix and new feature updates in FreeCAD 0.19 dev currently, so it's worth updating.
Did you try both dxf importers? There is a tick box "use legacy Python DXF importer", you may also have to tick "allow automatic download of Python importer code".
Here is a screenshot I don't think it's OS-related but depending on user settings.
Yes I`ve tried both. And I`ve checked the auto update function.
Thanks for the hint. I now download 0.19 and try it again.
@wmayer
Thank you for the screenshots. I`ll try your settings. The first window ("Modul auswählen") doesn`t appear on my machine...
@wmayer
Yes, importIL is part of the InventorLoader add-on. Insofar it's correct behaviour that you don't get this module selection dialog.
First of all a happy new year to everyone
After trying a lot of things, for example downloading version 0.19, i think I´ve found the problem why my FreeCAD doesn`t want to open the dxf.
The overall filepath + filename shouldn`t exceed a certain length. Otherwise the file doesn`t open like in my case. If I download my attached dxf file windows stores it in the download folder and everything works just fine. But if I move it into my workingfolder it again doesn`t work.
So if somebody has the same problem try to move it for example in the documents folder and rename the file to a short filename.
Thank you all for your help
Do you have some non ASCII characters in that long path? German user name, ...? Can you try with long path not containing those?
