how to turn off shading and display wireframe.
IFish4Tuna
Post by IFish4Tuna »
Hello -
I am looking for some help on setting the view to be wire frame without shading for submission to the US Patent office.
My drawings were rejected due to the shading. They only want black and white. I do not want to see hidden lines when displaying/printing. I only want to show the data that is facing based upon perspective.
I can not seem to figure out how to set the viewing to be wire frame based.
I looked in the documentation, and could not find any suggestions.
Thanks, Ed
NormandC
Re: how to turn off shading and display wireframe.
Post by NormandC »
Hello Ed,
Welcome here. The first thing you should do is read the "Read first before asking for help!!!" topic that is second in the list. This post explains what you need to provide to get the most efficient help.
On syntax, by definition wireframe shows every edges, including the hidden lines.
You cannot get what you want from the 3D view. To get a view in black and white with hidden lines off, you need to create a projected view of your 3D model. For that you will use the Drawing workbench.
This is a rendering mode that is not directly available. However, with some changes in your user settings you can simulate this effect. Here are the steps:
1. Set the display mode of the shape to Flat Lines (Yes, Flat Lines!)
2. Set the shape color of the part to black
3. Set the line color of the part to white
4. Now go to the preferences (Edit > Prefs > Display > Colors) and set the background color to black
Now you have black and white and you don't see hidden lines.
bejant
Post by bejant »
wmayer wrote:1. Set the display mode of the shape to Flat Lines (Yes, Flat Lines!)
Gives me this:
So right-click on the object in the tree view:
2. Shape color = White
3. Line color = Black
and in the Material section of the Display Properties window click the little box with three dots next to Default aqnd change all four colors to white. I left shininess at the default 20% and got this:
It's pretty close but how to see the curved edges?
Edit:
OS: Ubuntu 12.04.3 LTS
Platform: 32-bit
Version: 0.14.2911 (Git)
Hash: a2cba17d3f2faf44188298eb16211f7b6bc45358
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
20130101a_Tripod.fcstd
(20.74 KiB) Downloaded 96 times
NormandC
Post by NormandC »
Interesting trick, I didn't know it. But I still think it's much simpler to use the Drawing workbench.
Although bejant's file displays with errors.
NormandC
Post by NormandC »
bejant wrote:It's pretty close but how to see the curved edges?
Those are called "silhouette edges" and I don't think FreeCAD can display them in the 3D view because they don't really exist.
Which goes back to what I've been saying from the start... ;)
bejant
Post by bejant »
normandc wrote:Which goes back to what I've been saying from the start.
Before my other post I started playing around with the Drawing workbench as you advised the OP but got the same results with my file as you did. I didn't bother to post that because I didn't think it was helpful.
NormandC
Post by NormandC »
Even not knowing what type of shape Ed is working on, I still believe what I've been advocating is the best bet. There seems to be something odd with your model, I've never seen unwanted artifacts such as this line that crosses the page in any projected view I've made.
The Drawing view option has also another advantage: you can get a vector file out of it either in DXF or SVG format, so you can edit it to correct any oddities. That would be a lot harder on a bitmap image, which the only thing you can get out of a screen capture of your 3D view.
NormandC
Post by NormandC »
I forgot about another option: the Draft Shape2DView tool. It does create a correct 2D projection in the 3D view. All that is needed is to change the background to white.
20130101a_Tripod_Shape2DView.fcstd
(24.14 KiB) Downloaded 87 times
quick61
Post by quick61 »
Normand posted while I was in FreeCAD and before I got a chance to post this -
Normand, change the angle of the iso view and that line will go away. (one of the little bugs still in the drawing workbench me thinks) I tweaked the angle of the one in this file and it came out OK. Yea, the draft shape 2D view works too.
Black_and_White.svg
(27.02 KiB) Downloaded 247 times
This post made with 0.0% Micro$oft products - GOT LINUX?
