[Solved] Mimic FPS info on FullScreen
Nice to meet you
First post here.
I want to display some info on FullScreen, via Python, just like the FPS does,
info which will stay and will not rotate with camera.
I didn't had success so far, but most likely I don't know where to look for examples.
I'll appreciate any help.
So far I used Annotation, which is great and I like it, except it rotates with camera
so at each new view I had to re-position it.
cheers,
Dorin
Nice to meet you
First post here.
cheers,
Dorin
Re: Mimic FPS info on FullScreen
Hi and welcome to the forum!
Please explain what FPS is. I know it as FramesPerSecond, which makes no sense here.
Hi, thanks for quick reply
In FreeCAD, when at Preferences/3D View
[x] Show counter of frames per second
is enabled
In the bottom/left corner of Full Screen the FramesPerSecond info is shown
In the same way I want to show other properties, not FPS, say, the object rotation instead of FPS
I guess, must be a way, to display some info in Full Screen, info which will stay in that position regardless of camera rotation.
cheers,
Dorin
is enabled
cheers,
Dorin
Maybe if I'll add a video for better understanding.
In this one I used annotation to display the rotation of the cylinder.
The annotation is fine except when I rotate the camera, the annotation is moving along,
I need for that info to stay in that place of the Full Screen regardless of camera position.
I used this code for this video.
So what to use instead of annotation, I tried without success to have the annotation fixed, I guess I need a different approach.
cheers,
Dorin
from PySide import QtCore
import FreeCADGui as Gui
i=0
def update():
global i
FreeCAD.ActiveDocument.getObject("Cylinder").Placement = App.Placement(App.Vector(0,-10,-10),App.Rotation(App.Vector(0,1,0),-i), App.Vector(0,0,10))
App.ActiveDocument.getObject("Annotation").LabelText=[str(i)+"°"]
Gui.updateGui()
i+=0.1
if i>360:
i=0
timer = QtCore.QTimer()
timer.timeout.connect(update)
timer.start(1)
cheers,
Dorin
Here is a possible solution, using SuperImposition of coin3d :
Here is the coin3d doc : https://coin3d.github.io/Coin/html/annotated.html
from pivy import coin
textSep = coin.SoSeparator()
cam = coin.SoOrthographicCamera()
cam.aspectRatio = 1
cam.viewportMapping = coin.SoCamera.LEAVE_ALONE
trans = coin.SoTranslation()
trans.translation = (-0.98, 0.90, 0)
myFont = coin.SoFont()
myFont.name = "FreeMono,FreeSans,sans"
size = 24
myFont.size.setValue(size)
SoText2 = coin.SoText2()
SoText2.string = "Hello World"
color = coin.SoBaseColor()
color.rgb = (0, 0, 0)
textSep.addChild(cam)
textSep.addChild(trans)
textSep.addChild(color)
textSep.addChild(myFont)
textSep.addChild(SoText2)
activeDoc = FreeCADGui.ActiveDocument
view = activeDoc.ActiveView
sg = view.getSceneGraph()
viewer = view.getViewer()
render = viewer.getSoRenderManager()
sup = render.addSuperimposition(textSep)
# remove the Superimposition layer with :
# render.removeSuperimposition(sup)
Thank you very much!
Solved
cheers,
Dorin
Solved
cam.aspectRatio = 1
trans.translation = (-0.98, -0.35, 0)
myFont.name = "Arial"
size = 135
SoText2.string = "0°"
i=0
def update():
global i
SoText2.string=str(i)+"°"
Gui.updateGui()
i+=0.1
if i>360:
i=0
timer.start(1)
Dorin
Re: [Solved] Mimic FPS info on FullScreen
One more thing
I thought it will be easy..
how to have a multi-line string
tried
but it doesn't work
From Coin3D docu
---8<------------------
SoMFString SoText2::string
The set of strings to render. Each string in the multiple value field will be rendered on its own line.
It looks like a multi-line text needs to be given as a set of strings, but how?
Appreciate any help.
cheers,
Dorin
tried
SoText2.string = "line1\r\nline2"
From Coin3D docu
cheers,
Dorin
SoText2.string.setValues(0,3,["Hello", "World", "!!!!"])
If you want to reduce the number of items of a multifield node, you may need to reset the field beforehand:
SoText2.string.setValues(0,0,0)
Again thank you very much!
Makes perfect sense, tested, worked!
BTW, I noticed that after
it doesn't disappear automatically all the times,
and
seems to help but still are cases when the text stay, though it disappear at mouse click or hover (sometimes).
Tested on single line text only
This is not so important, I'm, maybe, yet to find how to force a redraw after render.remove.
thanks again,
Dorin
L.E.
Just thought, maybe I need to have a delay before render.render(), could be windows message queue issue.
render.render()
SoText2.string=""
render.render()
thanks again,
Dorin
L.E.
Maybe the touch() function of the scenegraph will work better ?
sg.touch()
