[Solved] Mimic FPS info on FullScreen
DorinDXN
Re: [Solved] Mimic FPS info on FullScreen
Post by DorinDXN »
Thanks again,
I'll try that as well.
cheers,
Dorin
DorinDXN
Post by DorinDXN »
Could be other thing!
Now I remember, sometimes FreeCAD shows, for an instant, like an old(previous) image on fullscreen,
I'm not saying is FreeCAD fault, could be some graphic accel. thing interfering, maybe..
cheers,
Dorin
DorinDXN
Post by DorinDXN »
Chris_G wrote: Mon Nov 02, 2020 11:27 am Maybe the touch() function of the scenegraph will work better ?
sg.touch()
That fixes it!
cheers,
Dorin
pablogil
Post by pablogil »
@DorinDXN,
I need this code but I'm stuck trying to remove the text, how do you exactly did it?
Thanks!
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
mario52
Post by mario52 »
Hi
pablogil wrote: Fri Jun 02, 2023 2:38 pm I need this code but I'm stuck trying to remove the text, how do you exactly did it?
as describe in the example viewtopic.php?p=444339#p444339
# remove the Superimposition layer with :
render.removeSuperimposition(sup)
maybe zoom the screen for refresh
mario
pablogil
Post by pablogil »
mario52 wrote: Sat Jun 17, 2023 9:37 pm Hi
mario
Yes, I solved it refreshing screen with
touch()
but as a first try it didn't worked for me as I was using it inside a script so I had to save sg into FreeCAD, that is:
FreeCAD.sg = view.getSceneGraph()
so that later I could call it with:
FreeCAD.sg.touch()
This way it works perfectly :)
Thanks!
mario52
Post by mario52 »
Hi
pablogil wrote: Sun Jun 18, 2023 3:41 pm so that later I could call it with:
FreeCAD.sg.touch()
good ... tanks
mario
mario52
Post by mario52 »
Hi
example creation sphere
import pivy
from pivy import coin
pointRotation = App.Vector(0.0,0.0,0.0)
ctPoint = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
itemctPoint = coin.SoSeparator()
sphere = coin.SoSphere()
sphere.radius = 0.5
color = coin.SoBaseColor()
color.rgb = (1.0, 1.0, 0.0)
move = coin.SoTranslation()
move.translation.setValue(pointRotation)
itemctPoint.addChild(color)
itemctPoint.addChild(move)
itemctPoint.addChild(sphere)
ctPoint.addChild(itemctPoint)
#ctPoint.removeChild(itemctPoint) # remove the point
mario
