Better algorithm for creating pitched roof (probably)?
- ragohix769
Re: Better algorithm for creating pitched roof (probably)?
I found some trouble with the Arch_roof tool with my project:
https://forum.freecadweb.org/viewtopic.php?f=23&t=64584
So knowing that there is another more powerful tool for roof, it's incredible!
It's a pity it's not in the addon manager of the Workbench, it should, so many users can test it easily.
As @ragohix769 suggested, this should go into an External Add-on?
Or better still, incorporated in official tool.
Thanks.
Can you indicate how this could be added into the External Add-on?Kunda1 wrote: ping
Would like to do so?ebrahim raeyat wrote: ping
Thanks.
- ebrahim raeyat
I added more tools and if I have time, I like to share it with community, like recognizing line type automatically like hip, valley and gutter.
Thanks, hope @Kunda would guide you how to add to the External Add-on
Several methods to create a workbench:
https://github.com/FreeCAD/freecad.workbench_starterkit
https://wiki.freecadweb.org/Workbench_creation
Or just look at the how other workbenches have done it https://github.com/FreeCAD/FreeCAD-addons/
How to add it to the Addon Manager:
https://github.com/FreeCAD/FreeCAD-addo ... collection
I can say that this solution is great! It would solve a lot of problems with pitched roofs.
Can you tell me if the component works in the latest versions of Freecad (0.20.2-0.21)?
I did everything according to the manual, but the workbench does not appear in the selection.
But I didn't find a component called euclid3 in the repository and installed the python-euclid3 I found (Manjaro-linux/ Archlinux)
An error is displayed in the console:
"During initialization the error "No module named 'euclid3'" occurred in /home/UserName/.local/share/FreeCAD/Mod/PitchedRoof/InitGui.py
Please look into the log file for further information"
We probably need to fix something in line 10 of polyskel.py. (from euclid3 import * ) To make it initialize.
I tried to remove this line altogether and the component went into freecad (but of course it doesn't work)
The available paths to the euclid3 in the system are in the picture.
I would change it myself, but I don't know python at all
UPD/
I put the euclid3.py file in the PitchedRoof component folder and it initialized.
But when I build the roof using the sketch, I get errors:
UPD/
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/roof3d.py", line 84, in execute
projection_face_points, wire_edges = extrude_pieces.create_3D_roof(base_obj, obj.angle, [], obj.angles)
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/extrude_pieces.py", line 81, in create_3D_roof
edges, outer_points_edges = roof_poly.get_skeleton_lines_of_roof(wire, angles)
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/roof_poly.py", line 59, in get_skeleton_lines_of_roof
skeleton = get_skeleton_of_roof(sketch)
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/roof_poly.py", line 19, in get_skeleton_of_roof
skeleton = polyskel.skeletonize(poly, [])
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/polyskel.py", line 484, in skeletonize
slav = _SLAV(polygon, holes)
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/polyskel.py", line 216, in __init__
contours = [_normalize_contour(polygon)]
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/polyskel.py", line 68, in _normalize_contour
contour = [Point2(float(x), float(y)) for (x, y) in contour]
File "/home/USERNAME/.local/share/FreeCAD/Mod/PitchedRoof/polyskel.py", line 68, in <listcomp>
Recompute failed!
- Scr_20230608_093449.jpg (39.17 KiB) Viewed 1667 times
There may be a misunderstanding . I communicate with the help of a translator
1. Solved the problem with launching the component. Probably the problem was in the cache after the first run.
Completely deleted folder /Mod/PitchedRoof and created it anew. I put file euclid.py in it, renaming it to euclid3.py (taken from https://github.com/euclid3/euclid3)
2. To set the thickness of the roof, you can use extrude on the Z (global) axis.
This is a great solution for multi-pitch roofs! Many thanks to the developer!
- ebrahim raeyat
Many thanks to you. I worked on it a little more, for example recognize various edge types automatically. If you interested, I can update the repo.ProjectBP wrote: ↑Sat Jun 10, 2023 10:15 am 1. Solved the problem with launching the component. Probably the problem was in the cache after the first run.
That would be really great!ebrahim raeyat wrote: ↑Tue Jun 13, 2023 2:17 pm Many thanks to you. I worked on it a little more, for example recognize various edge types automatically. If you interested, I can update the repo.
I haven't gotten to the serious roofing tasks yet, but any refinements would be helpful.
Thanks!
