Sketcher dimension lines with only one arrow!
GigiG
Post by GigiG »
Suddenly the dimension representations shows like the following snapshot (only one arrow at the end of dim. line), I don't why and when it started to happen.
OS: Linux Mint 20 (MATE/mate)
Version: 0.19.
Branch: unknown
Hash: f5710fb5cf551b026617f6248afd5cc2c48a3750
Python version: 3.8.2
Qt version: 5.12.8
0.0 VGA compatible controller: NVIDIA Corporation G92GLM [Quadro FX 3700M] (rev a2)
model name : Intel(R) Core(TM)2 Duo CPU T9800 @ 2.93GHz
cpu MHz : 1579.383
cpu MHz : 1601.611
X.Org version: 1.20.8
dimensions: 1920x1200 pixels (508x317 millimeters)
depth of root window: 24 planes
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
OpenGL vendor string: nouveau
OpenGL renderer string: NV92
OpenGL core profile version string: 3.3 (Core Profile) Mesa 20.0.8
Linux 5.4.0-48-generic
DeepSOIC
Re: Sketcher dimension lines with only one arrow!
Post by DeepSOIC »
Can you please try reset your freecad settings?
There is a button at the bottom of preferences dialog. But I recommend you to back up your config files, for both your convenience, and to help reproduce the bug. The directory of config files can be queried by typing App.getUserAppDataDir() to FC's python console.
Can you also try viewing sketch from the back? to see if the different arrows show up from behind? (then it's a face orientation issue)
GigiG
Post by GigiG »
from bottom:
after reset settings (before FC restart):
after FC restart:
[EDIT] My .FreeCAD zipped folder is too big to attach (8.1MB)
Just upload the user.cfg file. The whole directory contains all your addons too.
GigiG
Post by GigiG »
My user.cfg file
user.cfg.txt
renamed to .txt
(46.81 KiB) Downloaded 28 times
Syres
Post by Syres »
Fault occurs when the line 488 in user.cfg under View parameter group:
          <FCInt Name="RenderCache" Value="0"/>
or
          <FCInt Name="TransparentObjectRenderType" Value="1"/>
is present. I'll do a bit more digging into the code to see if I can have a go at preventing future occurrences.
Syres
Post by Syres »
So from a GUI point of view the setting that appears to be the root cause is in Edit > Preferences > Display > 3D View tab > Transparent objects:
With Backface Pass set causes the only one arrow head to show therefore changing to One Pass corrects the issue. It's now looking as though the Render Cache is a red herring and can be ignored.
zetka
Post by zetka »
Thanks, it happened to me suddenly too, the solution in the GUI helped.
