Constraint icons size at Sketcher edit (PR ready)
Elyas
Post by Elyas »
Hello everyone.
I'm just user at moment.
On my 180 dpi dysplay constraint icons are too small.
I look a bit source and want propose:
Now in ViewProviderSketch::renderConstrIcon
font.setPixelSize(11);
replace with something like:
font.setPixelSize( hGrp->GetInt("EditSketcherFontSize", 17) *0.7 );
It's not a code, just idea.
Separare editable properties not very needed, i thinking.
Thanks, sorry for my english.
Re: Constraint icons size
Elyas wrote: Fri Sep 04, 2020 12:46 pm It's not a code, just idea.
Can you make a before/after image showing your proposed improvement ?
vanuan
Post by vanuan »
Please read this:
https://wiki.freecadweb.org/HiDPI_support
Are you saying that the contraint icon size is currently derived from the font pixel size? And your solution is to make it configurable by the user?
I would rather replace this:
with this:
font.setPointSize(8)
But I'm not convinced that the icon depends on the font size:
    QImage icon = Gui::BitmapFactory().pixmap(type.toLatin1()).toImage();
It looks like it isn't. So you would have to specify the size:
  qreal pRatio = devicePixelRatio();
  qreal defaultCursorSize = 64;
  qreal iconSize = defaultIconSize * pRatio;
  QImage icon = Gui::BitmapFactory().pixmapFromSvg(type.toLatin1(), QSizeF(iconSize, iconSize)).toImage();
64 pixels is a 48 pt size. So maybe like this:
    QFont font = QApplication::font();
    font.setPointSize(48);
    QFontMetricsF qfm = QFontMetricsF(font);
    qreal iconSize = qfm.xHeight();
Maybe 48pt is too large of a size, so I would start with 24pt (32 virtual pixels, 64 device pixels at 200%) which should be equal to the cursor size.
Elyas
Post by Elyas »
vanuan wrote: Fri Sep 04, 2020 2:01 pm Are you saying that the contraint icon size is currently derived from the font pixel size? And your solution is to make it configurable by the user?
No. Currently contraint icon size is hardcoded by 11 pixel.
I'm not sure next: because it is on GL window it not controlled by common scale metod.
Already there is a "EditSketcherFontSize" property . It affect at displayed measure contraint but not contraint icon.
So i suggest to bind contraint icon size to "EditSketcherFontSize"
Elyas
Post by Elyas »
Kunda1 wrote: Fri Sep 04, 2020 1:40 pm Can you make a before/after image showing your proposed improvement ?
Some pictures to illustrate the subject.
Edit->preferences->Sketcher->Display
Default
Fontsize 12
Fontsize 17, QT_SCREEN_SCALE_FACTORS=2
Re: Constraint icons size at Sketcher edit
We have seen here several times requests to increase the constraint icons size. Especially users with HIDPI screens may benefit. The proposal to link it to the font size sounds reasonable to me; other options could be MarkerSize or to create a new configuration parameter.
chrisb wrote: Mon Sep 07, 2020 11:39 am We have seen here several times requests to increase the constraint icons size. Especially users with HIDPI screens may benefit. The proposal to link it to the font size sounds reasonable to me; other options could be MarkerSize or to create a new configuration parameter.
+1
Elyas
Post by Elyas »
I have prepared a scalable icon.
You can see they look at equal sizes with the font (35 hardware pixels)
Let's determine if a separate slider is needed or relate to the font size.
If we link, we set it equal or slightly less. Or a slider, but in a fraction of the font size.
vanuan
Post by vanuan »
Elyas wrote: Fri Sep 18, 2020 7:19 am I have prepared a scalable icon.
Do you mean the new setting with a number input to configure the constraint size?
I'd prefer a minimal amount of size related settings.
If we really need to provide user with font customization, I'd use QSS. Something like this:
CustomOpenGLWidget[type="constraintIcon"] {
  font-size: 12pt;
I think UI styling should be provided in a single text file. So that users can change multiple sets of sizes by a single select box.
Elyas
Post by Elyas »
Scalable icons, the size is related to the default font:
Main code:
void ViewProviderSketch::InitSizes()
    int defaultFontSize = QApplication::fontMetrics().capHeight();
    qreal ldpi = QApplication::desktop()->logicalDpiX();
    float k = 96./ldpi;
    ParameterGrp::handle hGrp = App::GetApplication().GetParameterGroupByPath("User parameter:BaseApp/Preferences/View");
    float view3D_factor = 1.25;
    constraintIconSize = hGrp->GetInt("EditSketcherFontSize", defaultFontSize*view3D_factor);
    coinFontSize = constraintIconSize * k;
    return;
Notes:
checked when"EditSketcherFontSize" was removed from users.cfg
view3D_factor - since it is a little more difficult to read in the view3D window, you should zoom in a little.
"EditSketcherFontSize" - would mean physical pixels.
